Rescue helicopter micro with 1S batteries
25 May 2015 19:34 #32974
Replied by mwm on topic Rescue helicopter micro with 1S batteries
Arakon is right about the resistor not being the way to go. However, having a 5V signal on a 3V line may be a problem even if you don't route power through the plane locator. May not, either. Lots of people use 6.6V LifePo's instead of 4.8V NiMH or 6V AA packs for Rx packs. Maybe try asking on a general RC forum instead of one devoted to third party firmware.
As to which servo to use - doesn't really matter. I'd take whichever channel you use least when flying, but all of them should be active enough to keep it from going off in the air.
- saidem
26 May 2015 16:53 #33013
by saidem
Replied by saidem on topic Rescue helicopter micro with 1S batteries
I agree with you that makes resistance a voltage drop depending on the current flowing through it.
I just saw that in fact all the entries and outputs from Lost Plane Finder Alarm are welded together, so it does not process any signal inside, which is even simpler. It is true that there could be a risk of mixing between 3V and 5V but I do not see what else. Here is the updated schematic.
Thank you very much everyone for your help.
Have a good day.
Have a good day.
Time to create page: 0.676 seconds
- Rescue helicopter micro with 1S batteries
