Where to buy a CX-10
21 May 2015 13:28 #32826 by mrbeefy
Where to buy a CX-10 was created by mrbeefy
Guys, where can i buy a deviation compatible CX-10 ? i was reading somewhere here that the green board will work but how can i tell by just looking at the model?
21 May 2015 15:38 #32829 by victzh
Replied by victzh on topic Where to buy a CX-10
There is no way, they'll send you an arbitrary choice of 3 models - red, green, or blue. And this is not necessarily a color of the copter board, it's the color of controller board. Red and green are now supported, blue is not.
I have an opposite problem - I need blue to test it, but there is no guaranteed way to get it ;-)
21 May 2015 16:06 #32830 by PhracturedBlue
Replied by PhracturedBlue on topic Where to buy a CX-10
you could go to the amazon warehouse with screwdriver in hand :P
21 May 2015 17:56 #32836 by Cereal_Killer
Replied by Cereal_Killer on topic Where to buy a CX-10
PhracturedBlue wrote: you could go to the amazon warehouse with screwdriver in hand :P
Dont overlook this option, of course Amazon isnt going to let you but I've headed down to my local hobby shop numerous times (BuddyRC) with tools to take something apart BEFORE I BUY IT to verify it was exactly what I wanted, again dont even bother asking amazon but your LHS should understand the issues and work with you.
In fact, Buddy sells CX-10's (or maybe CX-11's, I actually dont know the difference between them) but if it's that important to you, and you want to call Garry and set it up, I'll go there and check for you (hell Garry might even check him self), it's literally an 8 minute drive from my house (how lucky is that!).
22 May 2015 00:41 #32851 by mrbeefy
Replied by mrbeefy on topic Where to buy a CX-10
So i got the green cx-10 board but why is it not binding , selected yd171 protocol but no luck . What does it mean by select sky walkr protocol option ?
22 May 2015 01:30 #32852 by PhracturedBlue
As far as I know, you need a very recent nightly build (I think from may 20 or newer) to support the cx-10 green board. And of course, a nrf24L01 module installed.
22 May 2015 03:32 #32858 by mrbeefy
The deviation firmware that was installed on my 12s is the one you modified to fix the transparency on the screen. please integrate the changes on the latest build .
22 May 2015 03:34 #32859 by mrbeefy
Also if i install the latest nightly build will it screw up my screen again?
22 May 2015 04:05 #32861 by PhracturedBlue
I provided a fix in the test-build section:
www.deviationtx.com/downloads-new/catego...devo12-lcd1-5-test-4
Please report back if the screen is ok.
22 May 2015 04:20 - 22 May 2015 04:28 #32862 by mrbeefy
PhracturedBlue wrote: I provided a fix in the test-build section:
yes screen is tested good and yesssssssss the cx-10 is binding!!!!
looking forward in getting this fix integrated to your nightly builds thanks!
Last edit: 22 May 2015 04:28 by mrbeefy.
23 May 2015 17:58 #32896 by lasakro
Replied by lasakro on topic Where to buy a CX-10
victzh wrote: I have an opposite problem - I need blue to test it, but there is no guaranteed way to get it ;-)
victzh,
If you are here in the states and want to trade a green for a blue I'll pay to ship one of my blues ones out to help further the cause. PM if you are interested.
Bob
24 May 2015 13:13 #32923 by mrbeefy
DigitalMD wrote: Forget the CX-10 and buy the WlToys V676, looks identical but works consistently with Deviation nightly build.
so the yaw rate and flight characteristic is the same as the green board?
Time to create page: 0.720 seconds
