DANGER! SLT protocol with fixed ID
29 May 2015 18:56 - 29 May 2015 18:56 #33200 by battlemachine
DANGER! SLT protocol with fixed ID was created by battlemachine
I finally found the cause of all my SLT helicopeters crashing out of control. if you have two model with different model ID, you have to turn off your transmitter for 5sec when changing model with different ID, BEFORE you try flying your model, or otherwise the transmitter/module will get mixed with the other ID, causing your heli to crash.
you could also avoid this by binding all your heli/planes to a single fixed ID. or don't use fixed ID at all.
Last edit: 29 May 2015 18:56 by battlemachine.
Time to create page: 0.038 seconds
