Re-flashing Devo 7e bootloader?
23 Sep 2016 01:30 #54139 by steadfast4life
Replied by steadfast4life on topic Re-flashing Devo 7e bootloader?
Is this the same connections for the DEVO 10? Need to reflash my bootloader.
23 Sep 2016 13:10 #54170 by Cereal_Killer
Replied by Cereal_Killer on topic Re-flashing Devo 7e bootloader?
I was looking for this thread for you last night glad you found it!
Yes it's the same process but the connections (while the same) will be in different locations and you may need to adjust the addressing.
23 Sep 2016 18:52 #54182 by steadfast4life
Great! One more question. I've got the ST LINK V2 with 10 pins (RST, SWIM, GND, 3.3V, 5V, SWCLK, SWDIO, GND, 3.3V, 5V). do I need to buy a twenty pin ST Linker to get the additional connections?
23 Sep 2016 23:54 #54191 by Cereal_Killer
No what you have is it. I've only done a u7e not a 10 so maybe the names are just a little off? I use the same 10-pin STLINK v2
24 Sep 2016 03:10 #54195 by steadfast4life
Great, thanks! I'll let you know how it turns out! BTW, your day job looks amazing!
29 Sep 2016 03:44 #54388 by steadfast4life
I disassembled and reassembled the tx and the bootloader worked so I didn't have to reflash the bootloader. Thanks for your help. Everything is good again!
28 Jan 2017 08:37 #58462 by calico
Replied by calico on topic Re-flashing Devo 7e bootloader?
PhracturedBlue wrote: It turns out I had to do this today, so I can be pretty specific.
1st you need an stlink-v2 and a copy of the devo7e bootloader
You'll be using the 20pin header on the stlink.
on the 7e board, there is a 5-pin unpopulated header below the MCU, one pin is labeled RESET. We;ll call this pin '1'
connect pin1 (reset) on the Tx to pin 15 (NRST) on the stlink
connect pin2 (tms) on the Tx to pin 7 (TMS) on the stlink
connect pin3 (tck) on the Tx to pin 9 (TCK) on the stlink
connect pin4 (GND) on the Tx to pin 20 (GND) on the stlink
connect pin5 (Vdd) on the Tx to pin 1 (Vcc) on the stlink
just above the 5-pin header is a 2-pin unpopulated header. this is BOOT0. you need to place a jumper between the 2 pins.
On the upper left of the 7e circuit board is another 2-pin unpopulated header. This is power bypass. You'll need to short these together too, but not yet.
You need to install the software for the stlink-v2 to your PC (Windows only)
Now, plug in the st-link to the PC. It should be detected and drivers installed
Startthe ST-Link software.
make sure there are batteries in the Devo7e, and apply the jumper across the power bypass.
Now press the connect button in the stlink software on the PC. It should connect. If you get an error message, you have a connection wrong somewhere.
You will need to do a bulk-erase of the chip 1st. then you can load the bootloader and do a program&verify.
your bootloader is now loaded.
You need to disconnect the jumper on BOOT0 and power bypass before you do anything else.
I have ST-link V2 usb which has 10 pins only,
I can not find the pin connection using this to flash bootloader.
don;t want to kill the TX again...
anyone has the pin connections ?
28 Jan 2017 17:15 - 28 Jan 2017 17:18 #58478 by HappyHarry
Replied by HappyHarry on topic Re-flashing Devo 7e bootloader?
for the 10pin st-link the connections are
pin2-tms > swdio
pin3-tck > swclk
pin4-gnd > gnd
pin5-vdd > 3.3V
be sure not to use the 5V line as it will damage the mcu.
[edit]
silpstream has a great tutorial on his site for flashing the bootloader >> silpstream.com/103/ultimate7e-flashing-the-bootloader/
[/edit]
Last edit: 28 Jan 2017 17:18 by HappyHarry. Reason: added link to silpstream's howto
29 Jan 2017 01:11 - 30 Jan 2017 08:54 #58515 by calico
I can not find the 2 pins to be "jump" on devo10 and the power pins ?
Do i have to jump those on devo10?
Last edit: 30 Jan 2017 08:54 by calico.
02 Apr 2017 17:31 #61084 by nathaniel52441
Replied by nathaniel52441 on topic Re-flashing Devo 7e bootloader?
I don't know if this thread is dead or not but I just did this process on the 12e and it writes successfully but still nothing happens when I turn it on nothing happens still. Is there something I'm missing in this process? The one thing I did notice is there's not 12e bootloader just the f12e and 12, I've tried both to no avail
04 Apr 2017 20:02 #61180 by HappyHarry
I don't think we have a copy of the 12e bootloader, why you need to flash it escapes me also?
04 Apr 2017 20:03 #61181 by FDR
04 Apr 2017 21:42 #61191 by HappyHarry
ouch :/ perhaps a nice warning about tx compatability on the bootloader jump page to the google drive is in order?
04 Apr 2017 21:46 #61192 by nathaniel52441
Possibly, I'll let you know more information tonight when I flash the 12e dfu. But as far as compatibility I can 100% confirm that the Devo 10 bootloader does work on the 12e.
05 Apr 2017 00:04 #61194 by nathaniel52441
Well I can't load the 12e DFU through the install/upgrade tab or the DFU tab, it just greys out all the options and the walkera utility bricks it so I'm pretty much stuck with a Devo 10 in a Devo12e body. Atleast until the 12e bootloader is available which may be never but I'll keep looking!
23 Oct 2020 03:04 #76913 by is fpv
Replied by is fpv on topic Re-flashing Devo 7e bootloader?
Hi Is there any demonstrate or picture how to do this?
I'm quite not understand.
Time to create page: 0.303 seconds
