Model File Utility (Updated)
- greenfly
23 Jun 2015 20:46 - 14 Aug 2015 05:00 #34562
by greenfly
Model File Utility (Updated) was created by greenfly
I wrote this little utility to manage the model files on my Devo 7E running DeviationTX. The program
works by searching for a removable drive that looks like a Deviation install. When it finds one
it will look at all the models and list them in the main window. From there you can manage your
model files using the buttons on the right.
Right now, it will
Just download, unzip and run the executable.
Sorry, Windows only... and you will need the .Net Framework 4.0 installed.
See this post for the cross-platform version.
Right now, it will
- Backup your models folder
- Restore one or all of your models
- Import/Convert an external model file into your models folder
- Move models up and down in the list
- Copy models
- Clear a model slot
- Rename a model
Last edit: 14 Aug 2015 05:00 by greenfly. Reason: New Cross-Platform Version
- Durete
- RedSleds
23 Jun 2015 22:12 #34571
by RedSleds
Replied by RedSleds on topic Model File Utility
Sweet! I could have used this a few days ago, and saved myself a headache, or two. Thanks!
- dc59
24 Jun 2015 00:08 #34576
by dc59
Replied by dc59 on topic Model File Utility
Good Job !!!
Excellent.
Excellent.
- Cereal_Killer
24 Jun 2015 00:40 #34577
by Cereal_Killer
Replied by Cereal_Killer on topic Model File Utility
Wow, very cool, I really like the move up / down option ,I often spend 10 minutes before going out to the field reordering my model files to get the one's I'm about to fly up at the top and next to each other (and I have A TON), usually a long and boring job, with your utility it takes (very literally) 20 seconds!
- greenfly
24 Jun 2015 01:21 #34578
by greenfly
Replied by greenfly on topic Model File Utility
Thanks everyone!
I've always liked the idea of model files. They make it easy to backup, read, etc without any special tools. With that flexibility though comes the risk of making a mistake... and makes some tasks a drudgery... especially if you like to play with your model settings or like to keep things nice and organized.
Or have a LOT of birds!
- gordonzo
24 Jun 2015 03:38 #34579
by gordonzo
Different fly for different guy.
Replied by gordonzo on topic Model File Utility
Very nice! Thank you.
Works with the Devo 10 as well.
g
g
- Moeder
24 Jun 2015 16:02 #34599
by Moeder
Replied by Moeder on topic Model File Utility
Nice tool. Now if we could just integrate this into the platform independent java dfu uploader and add a model editor/creator, we would have the perfect Deviation Manager
- greenfly
24 Jun 2015 18:56 - 24 Jun 2015 19:38 #34604
by greenfly
I just wanted to mention that you can assign an exe to open the modelX.ini file by editing the file...
Just change the "ModelEditor" key value setting to the path of your editing exe. For instance, I default mine to Notepad++...
Note that 1) you have to use double slashes and 2)For Win7 you may need to use 8.3 filenames.
Then all you have to do is double-click the model name.
Moeder wrote: ...add a model editor/creator...
ModelFileManager.exe.configJust change the "ModelEditor" key value setting to the path of your editing exe. For instance, I default mine to Notepad++...
<add key="ModelEditor" value="C:\\Program Files (x86)\\Notepad++\\notepad++.exe"/>Note that 1) you have to use double slashes and 2)For Win7 you may need to use 8.3 filenames.
Last edit: 24 Jun 2015 19:38 by greenfly. Reason: Addition
- robbe
25 Jun 2015 14:05 - 25 Jun 2015 14:19 #34651
by robbe
Replied by robbe on topic Model File Utility
Pretty nice! Thanks!
Just a question: could it be that the program can not handle more than 30 model files?
I get an error and have 50 model files on my Devo 10 (yes, most of them are empty
EDIT:
Did another test with only 30 model files and no error!
So it works pretty fine with the standard settings.
EDIT2:
Handling with more than 30 files ok, but with "empty" files error.
I copied a default config to all "empty" files and everything went smooth
EDIT:
EDIT2:
Last edit: 25 Jun 2015 14:19 by robbe.
- greenfly
25 Jun 2015 14:44 #34653
by greenfly
Sorry about that. It expects for there to be a file for every model slot and that the model files are contiguous. So if you deleted any then that would cause a problem.
The program will support up to 256 models. One way to generate more model files is to "Move Down" a model down past the end of your list. The program will add an empty file to accommodate..
- robbe
25 Jun 2015 16:17 #34654
by robbe
i have to say sorry
, because I put empty files in the models.
Good to now it supports up to 256 models, great!
- bugman72
03 Jul 2015 04:09 #35019
by bugman72
Replied by bugman72 on topic Model File Utility
This honestly has to be one of the greatest breakthroughs in Devo development! LOL! This is EXACTLY what I've been wanting. Thank you so much greenfly for creating this. It is now an invaluable tool for my Devo development.
- greenfly
03 Jul 2015 15:53 #35057
by greenfly
Thanks bugman72!
I am very glad to hear that others are finding the app useful. Myself, I use it quite regularly. I guess I enjoy the endless tweaking and fine-tuning of my small fleet of quads.
- Richard96816
06 Jul 2015 05:11 #35148
by Richard96816
Replied by Richard96816 on topic Model File Utility
Very nice. Thanks!
- Alias_Hendrik
06 Jul 2015 10:21 #35153
by Alias_Hendrik
Replied by Alias_Hendrik on topic Model File Utility
Greenfly thanks for this! Really a big thanks! I just downloaded it and it is joy to manage my ini's and leftover test ini's. Not to mention the back-up function with date, super! And a double click opens Notepad ++. This is really valuable software! Thanks again
- greenfly
28 Jul 2015 18:07 #36259
by greenfly
Replied by greenfly on topic Model File Utility (Updated)
Just an FYI.... I have updated the utility (in the first post) with a few more features. To use, you can simply replace the old files with new ones.
One new feature can use mwm's model file conversion routine from here . If you place a copy of the "straight.exe" and "default.ini" in the same directory as the Model File Manager, you can make these changes to the config to activate the model conversion during import.
<!-- Set this to the exe that will convert a model file during import -->
<!-- Note: With no path it will assume it is in the app dir -->
<add key="ModelConverter" value="straight.exe" />
<!-- Set this to be the arguments for the above command where... -->
<!-- {0} = model file being imported -->
<!-- {1} = current model file being overwritten -->
<add key="ModelConverterArgs" value="{0} {1} -c default.ini" />- mwm
30 Jul 2015 21:26 - 30 Jul 2015 21:36 #36375
Replied by mwm on topic Model File Utility (Updated)
Any chance you could look at porting this to Mono? That way, you could do builds that would run on Linunx, the Mac and other U nix systems. The tools run on Windows and from inside of VB, and has tools to help transition from .NET. I looked at it, but I'd have to learn the tools it works with in order to use the tools I need to do the port, so it might be quicker for you if you have the bandwidth.
Whoops: Forgot to give you the link: www.mono-project.com/
Last edit: 30 Jul 2015 21:36 by mwm. Reason: Add link.
- greenfly
30 Jul 2015 22:18 #36380
by greenfly
That's an excellent suggestion.
I have actually been looking into ways to make it cross-platform. The shortest route for me would be Mono and since it looks like it has a future now, I will probably do that. I run Windows in my day job, but am a Linux junkie at home.
Thanks for the pointer... I needed someone to get me going on this.
- Richard96816
30 Jul 2015 23:47 #36382
by Richard96816
Replied by Richard96816 on topic Model File Utility (Updated)
Very cool.
Time to create page: 0.139 seconds
- Model File Utility (Updated)
