Hold switch damaged
- IKKI
02 Jul 2015 11:30 #34977
by IKKI
Replied by IKKI on topic Hold switch damaged
Nothing changes and Hold FmodE work together, or one excludes the other.
The slopes are below the display how do I remove it?
- IKKI
03 Jul 2015 21:06 #35060
by IKKI
In case you can not solve, someone explain to me would know how to get around the problem? Perhaps adding buttons? Thank you very much, I will not throw it ...
- RedSleds
04 Jul 2015 20:26 - 04 Jul 2015 20:34 #35113
by RedSleds
Replied by RedSleds on topic Hold switch damaged
Well, if you tried all of my suggestions, including re-flashing of a fresh nightly build firmware with proper hardware.ini for your switch configuration, and still having problems, I am pretty much all out of ideas.
Maybe upload your hardware.ini and model.ini so we can have a look at them?
One other thing is, on a picture of your board mods that you uploaded:
Some of the connections to the CYRF module are obscured by the red and white wires leading to the 3.3v/VDD. Can not really see what is going on under there, but some of the solder beads appear to be very close to being in contact with each other. Not sure if that could result in your switch error if there was some kind of short at one of those points, but you might want to check and see if there is some tiny, stray, beads of solder causing havoc.
Other than that, I don't have any more ideas.
Last edit: 04 Jul 2015 20:34 by RedSleds.
- IKKI
06 Jul 2015 18:13 - 06 Jul 2015 18:20 #35174
by IKKI
Last edit: 06 Jul 2015 18:20 by IKKI.
06 Jul 2015 22:15 - 06 Jul 2015 22:16 #35180
Replied by PhracturedBlue on topic Hold switch damaged
I didn't see a response to my question. Did you check to see if there is a short between the 2 pins I circled with the switches unplugged? If you answered, I missed it.
A work-around is to do the 2x2 or 3x2 switch mod, which should work fine to give you two new 2-way or 2 3-way switches. You could use those instead of your existing switches.
Last edit: 06 Jul 2015 22:16 by PhracturedBlue.
- IKKI
06 Jul 2015 22:23 #35181
by IKKI
I'm sorry, yes the two pins that you indicated and that I have circled, the tester always give they in short circuit. Could you indicate the link of these changes? So I try to do them. Thanks
07 Jul 2015 01:16 #35184
First off:
If you leave one switch connected and disconnect the other switch (unplug it) does the 1st switch work as expected (both HOLD and FMODE will move together of course). That would get you one working switch.
The switch mods can be found here:
2 2-way: www.deviationtx.com/forum/how-to/1436-ad...tches-to-the-devo-7e
2 3-way: www.rcgroups.com/forums/showthread.php?t=1918045
I am sure there are better links, but I don't have them handy.
- IKKI
07 Jul 2015 01:55 #35185
by IKKI
Yes, at this point use Hold that will work both Hold that FModE in pairs. I add the missing links, exploit FModE as first additional key and try to put a trigger button on the back or the left I use to flip. Hopefully functions. Then from what I understand it would be enough to understand how to assign different keys through. ini
Time to create page: 0.394 seconds
- Hold switch damaged
