Walkera V450D03
- niteliter
18 Jul 2015 13:01 - 18 Jul 2015 15:12 #35606
by niteliter
Walkera V450D03 was created by niteliter
OK, I purchased a Walkera V450D03,without the battery.NOW I have 2 questions:
what type of plug is on the end of that battery,I have maybe 8 11.1 3S batteries for my other copters,and quads,but they have different ends,
And where would the best place be to get a battery from?
I was thinking maybe change the plug on the Heli to match my other batteries.........an idea from the mind of a cheapo.......well, sometimes a cheapo............actually.maybe alotta times.............
and if I do R/R the end,can I use any standard flexible 12,or 14 stranded wire?
Thanks Much.....
Thanks Much.....
Last edit: 18 Jul 2015 15:12 by niteliter. Reason: add picture
- Thomas.Heiss
18 Jul 2015 14:43 - 18 Jul 2015 14:45 #35611
by Thomas.Heiss
Replied by Thomas.Heiss on topic Walkera V450D03
You will probably void warranty if you re-solder the plug on the ESC.
Spektrum support e.g told me that.
Personally I solder my own adapter cables, which include the telemetry sensor cable connected to +- in the middle.
You must be careful about what AWG wire you use depending on the plugs (e.g blue EC3/5, green MPX, yellow XT60, etc.).
If it is too thick you may fail to solder the wire end into the plug or goldie.
Last edit: 18 Jul 2015 14:45 by Thomas.Heiss.
- Zaphod
19 Jul 2015 00:12 #35643
by Zaphod
Replied by Zaphod on topic Walkera V450D03
I changed all my lipos and esc to XT60 plugs. The standard plug used on the V450D03 is a 3.5mm bullet plug so very easy to make your own on the lipo of your choice or an adaptor cable.
They fly well on a 11.1 3S 2200 mah lipo. Some have reported the 2700mah gives better balance.
- niteliter
19 Jul 2015 00:35 #35644
by niteliter
Replied by niteliter on topic Walkera V450D03
I currently have 4000 mah in it to keep the seat warm,and it feels balanced.
I have met with a speed bump today,I tried to do the upgrade,I got as far as the "upgrade has been successful",and shuit down,but when I held down the ENT with power up,NO USB sign.bummer,Im sure its my win 7 64bit,Ill try at a later date,I i have considered bullet leads...........just so darn busy here...........
Time to create page: 0.223 seconds
- Walkera V450D03
