Antenna plugged-in
- Fernando
08 Sep 2015 06:10 - 08 Sep 2015 06:15 #37550
by Fernando
Antenna plugged-in was created by Fernando
Hi everyone,
I have installed a NRF24L01 module on my Devo 8S and hardly ever I use it with models that make use of main transmitter module, I mean the one who has the original antenna attached on top. Is it necessary to plug-in that antenna to the Devo transmitter in those cases? in other words, Does the transmitter activate the main internal module when I am using just the NRF24L01? As you know, this module has its own antenna, I want to be sure of that to avoid any damage...
Thank you.
Thank you.
Last edit: 08 Sep 2015 06:15 by Fernando.
- 24inwork
08 Sep 2015 11:05 #37566
by 24inwork
Replied by 24inwork on topic Antenna plugged-in
wanted to ask the same question, does anybody know the answer?
- aMax
08 Sep 2015 12:40 - 08 Sep 2015 12:45 #37568
by aMax
Replied by aMax on topic Antenna plugged-in
At least at power on the CYRF is aktiv....and if you go to menu and select an empty modell file, the module is selected as well ( standart)
You may risk your pa in long-term.
Edit: Get a dummy load for the module not in use.
Last edit: 08 Sep 2015 12:45 by aMax.
- Fernando
09 Sep 2015 09:49 - 09 Sep 2015 10:22 #37593
by Fernando
Replied by Fernando on topic Antenna plugged-in
Hi aMax, sorry but I don't know exaclty what you mean with "dummy load". Where can I purchase it? May be is something like this?
www.banggood.com/SMA-Male-RF-Coaxial-Ter...50-Ohm-p-927353.html
Thank you.
EDIT: I found the answer here .
"How does a dummy load work? It's just a big dumb resistor, non-inductive so that the load is 100% resistive. Essentially, it works by converting nearly all of the transmitter's power to heat instead of radiating it as electromagnetic radiation."
I think then the "dummy load" of BG could be useful but I am not really sure if 50Ohm is OK or may be I need 75Ohm, it seems to be 50Ohm but not sure.
Thank you.
Last edit: 09 Sep 2015 10:22 by Fernando.
- aMax
09 Sep 2015 10:47 - 09 Sep 2015 11:11 #37594
by aMax
Attention, these from BG will not fit your antenna sockets, they are SMA. Seach on ebay some RP-SMA loads.
I build some on my own from connectors that have been left after antenna mods.
These 50 Ohms are standart.
Fernando wrote: Hi aMax, sorry but I don't know exaclty what you mean with "dummy load". Where can I purchase it? May be is something like this?
Last edit: 09 Sep 2015 11:11 by aMax. Reason: adding a photo
- Fernando
09 Sep 2015 10:57 #37595
by Fernando
I will check this afternoon on my transmitter and antenna but I found this....
www.deviationtx.com/forum/6-general-disc...h-gain-antenna#11860
Another user said the Devo8S antenna has a SMA Male, so the one BG is selling. But I will not order anything until I check.
Thank you aMax.
Thank you aMax.
- Fernando
10 Sep 2015 06:19 #37622
by Fernando
Hi, Yesterday I checked the type of connector the Devo8s has and the guy from this post is right:
Here is a picture I took yesterday:
So the one is selling BG is valid for this transmitter.
Cheers!
Cheers!
- Fernando
30 Sep 2015 06:41 #38264
by Fernando
Hi, just for your info.
Received the dummy load from Banggood and fits perfect on my Devo 8s.
Regards.
Regards.
Time to create page: 0.322 seconds
- Antenna plugged-in
