Devo8S tx_power when using PPM protocol
- christian_cph
05 Nov 2015 19:08 #39622
by christian_cph
Devo8S tx_power when using PPM protocol was created by christian_cph
I have set up a model for use with my PC and RealFlight. In the Model Setup i have set Protocol to PPM. Everything is working perfect, but when i set the Protocol to PPM, the Tx Power is fixed at Default. It looks like my Devo8S is transmitting at Full Power. In the model.ini i have tried to set tx_power to 100uW, but it is still transmitting at Full Power. It would be nice if I was able to set Tx Power to 0 or at least 100uW, saving the batteries. Is there a way to fix this ? Or maybe this is a suggestion for a future release of Deviation
05 Nov 2015 19:53 #39625
Replied by FDR on topic Devo8S tx_power when using PPM protocol
Actually when the protocol is PPM the tx doen't transmit at all, that's just the default display value...
- christian_cph
05 Nov 2015 23:44 #39630
by christian_cph
Replied by christian_cph on topic Devo8S tx_power when using PPM protocol
@FDR Sounds good. Thanks for quick response
Time to create page: 0.486 seconds
- Devo8S tx_power when using PPM protocol
