Devo 10 potentiometers?
07 Dec 2015 01:45 - 07 Dec 2015 01:45 #40642 by SilbernerSurfer
Devo 10 potentiometers? was created by SilbernerSurfer
I have 2 potentiometers on my Devo 10.
Is a 6-pos-switch available? Can I use the Taranis 6-pos-switch?
Is a potentiometer available which locks in the middle position?
Thanks in advance!
Last edit: 07 Dec 2015 01:45 by SilbernerSurfer.
07 Dec 2015 03:32 #40644 by mwm
Replied by mwm on topic Devo 10 potentiometers?
There's no software support for a 6-position switch, though you could certainly wire in something that just created six fixed positions. Ditto for using a pot with a center indent of some sort.
The voice alerts test build (see deviationtx.com/forum/builds/5089-voice-alerts-test-build ) includes a "beep" mixer type that lets you cause a channel to beep (or, if you've added the audio player, play an audio file) at any given value, like when it's centered.
Time to create page: 0.770 seconds
