Bricked Devo 10? HELP please
- NutraBind
12 Dec 2015 11:33 #40855
by NutraBind
Bricked Devo 10? HELP please was created by NutraBind
Hi guys,
I'm desperately looking for advice. I'm afraid I killed my brand new Devo 10.
As first step, I have installed Deviation 4.0.1 - all fine, TX powers up.
As next, I wanted to upgrade to the latest nightly. Same process, but after the DFU upgrade the tx does not switch on. No screen, no beep, nothing.
Battery voltage OK. I tried removing batteries, hoping that helps. Nope.
I cannot switch on normally, not in Upgrade or USB mode.
Is there a way to hard reset it or to force to DFU mode? Any other idea?
All help is greatly appreciated.
12 Dec 2015 15:07 #40863
Replied by FDR on topic Bricked Devo 10? HELP please
Disconnect the battery and wait a little longer, say 10 minutes.
Then put back the battery, and switch it on in DFU upgrade mode.
If it don't do it, that is usually a hw problem.
You can't brick the tx with a fw upgrade, because the bootloader is not overwritten.
- NutraBind
13 Dec 2015 15:24 - 13 Dec 2015 15:43 #40877
by NutraBind
Replied by NutraBind on topic Bricked Devo 10? HELP please
Thanks for the fast response. I'm afraid you are right about the hw problem. I cannot put to DFU mode either (at least not by EXT and Power On).
The only suspicious thing is that it failed right after the upgrade. Maybe only coincidence.
Right now I try to get warranty solution - it happened on day 1, not even opening (yet) the case.
Edit: Fixed.
Tried once more to put into DFU mode but this time USB cable plugged into the PC already. And I saw miracle in the form of the upgrade screen. From here putting on the 4.0.1 was easy and quick.
I'll leave the nightly install to later until I need it. (Though I do not think the nightly has much to do with my issue; probably just bad luck.)
Edit: Fixed.
Last edit: 13 Dec 2015 15:43 by NutraBind. Reason: Issue fixed
Time to create page: 0.401 seconds
- Bricked Devo 10? HELP please
