D10, Vertical trim responds to pot trimmers.
11 Jan 2016 04:24 - 11 Jan 2016 04:49 #41612 by Cereal_Killer
D10, Vertical trim responds to pot trimmers. was created by Cereal_Killer
Hello, tried searching, usually I've got some pretty good Google-foo but didn't find ANYTHING on this...
I'm trying to setup a timer (stopwatch) to be reset with the up trim of the left pot, I got it all setup and working, only problem is it also works from the up button of the left stick. Tried switching to the lower buttons same results. Also tried switching to the right pot (AUX5) trimmer and same thing (but with the right stick vertical trim).
I see where in the trim settings it lists (e.g.) RV+, RV-, RH+,RH- and R+,R- (assuming the "R+ and R- is the pot trimmers) so I know they're ID'd as separate inputs but how can I make them stop both doing the same thing when I only want one (and only have one set to be the input to the virtual channel)?
Last edit: 11 Jan 2016 04:49 by Cereal_Killer.
11 Jan 2016 17:51 #41637 by TomPeer
Replied by TomPeer on topic D10, Vertical trim responds to pot trimmers.
I use this:
[virtchan4]
name=Reset
template=complex
[mixer]
src=Virt4
dest=Virt4
scalar=0
[trim8]
src=Virt4
pos=TRIM_L+
step=193
value=-100,0,0
[timer1]
src=THR
resetsrc=Virt4
[timer2]
type=countdown
src=THR
resetsrc=Virt4
time=300
