telemetry module WK-CTL01-D, Binding problems
18 Jan 2016 08:30 #41895 by TB34
I have a DEVO 12S and a1202 RX with the last DeviationTX firmware.
I have a WK-CTL01-D telemetry module I would like to use with the 1202 RX (Walkera).
How can I bind the RX AND the module together?
Is the module powered by the RX (aux. output link)?
Does someone know how to proceed?
Thank you for your help.
I'm sorry about my poor english so i'm french :( .
Have a nice day
18 Jan 2016 09:24 #41896 by FDR
They need to be bound at once.
Make sure you don't use fixed id in your receiver. If it is bound with fixed id, you need to clear it first.
Then power up the tx, and within a few seconds power up both the receiver and the telemetry modul (they are probably powered from a simple source anyway).
When the rx (and the telemetry module) is bound, you can assign a fixed id if you want, and send it to the rx (and telemetry module too). That way next time you can switch the rx and tx in any order, they will still remain bound.
18 Jan 2016 11:07 #41897 by TB34
Thank you FRD
Your answer is very clear.
I'll try that this evening.
26 Jan 2016 06:46 #42226 by kenzie25
Replied by kenzie25 on topic telemetry module WK-CTL01-D, Binding problems
good answer, i'll try it.
Time to create page: 0.196 seconds
