Can Devo10 and Quanum head tracker work together?
- Nano02
21 Jan 2016 04:32 #42008
by Nano02
Can Devo10 and Quanum head tracker work together? was created by Nano02
Whats up pilots!
I have Devo10+Devention 4.0.1 and I am triying to use the Quanum 3 axis no drift Head Tracker thru the trainer port.
I already set 3 channels on PPM "EXTEND" on CH6, 7 and 8, but the output signal from the radio is erratic as I can see in "Channel monitor" and connecting 3 servos to the Rx.
When I connect the head tracker to my PC everything is ok on GUI, but not when connected to the radio.
Help please!!
Help please!!
- Cereal_Killer
21 Jan 2016 04:44 #42009
by Cereal_Killer
Replied by Cereal_Killer on topic Can Devo10 and Quanum head tracker work together?
Can you post a link to specs of the Quanum head tracker? Somewhere it should tell you the delta pulse width and stuff like that... using that info you can fine tune your devo to clean up the jitter your having.
- Nano02
25 Jan 2016 13:26 #42201
by Nano02
Replied by Nano02 on topic Can Devo10 and Quanum head tracker work together?
Thanks for your ultra fast response!
Hobbyking erase the product page of this item, so there is only RCgroups forum:
http://www.rcgroups.com/forums/showthread.php?t=2440420
- Nano02
30 Jan 2016 02:40 - 30 Jan 2016 02:44 #42390
by Nano02
I can't find anything about the delta pulse width in RCgroups.
It is mentioned in the User Documentation included in a ZIP file with the GUI, but I don't know how to play with that values in GUI. (see attachments)
Regards.
Regards.
Last edit: 30 Jan 2016 02:44 by Nano02.
- Nano02
30 Jan 2016 02:48 #42391
by Nano02
User documentation attached
- Nano02
15 Jun 2016 00:15 #50635
by Nano02
Can anybody help me?
Thanks in advance.
Thanks in advance.
Time to create page: 0.198 seconds
- Can Devo10 and Quanum head tracker work together?
