Devo 10 with Apm 2.6
15 Mar 2016 14:44 - 15 Mar 2016 17:46 #44601 by Josephking87
Devo 10 with Apm 2.6 was created by Josephking87
Hey guys,
I'm new here so not sure if I'm posting in the right spot.
I'm trying to find a model for the devo 10 and Apm using 6 flight modes.
I'm new to the devo 10 and deviation so I prefer something I can just load and not have to mess with it for setting up. I will however do my best to learn all this stuff. I'm coming from a turnigy 9x so this is a huge change.
I did find a model for Apm and I think it was a devo 8.. With that though I feel like I would have to change things..
Also what would be a good receiver for this setup? Lemonrx, orangerx or spektrum.. This will be on a s500 quad.
I wonder if the qrx350 settings would work since it uses Apm??? Hmm lol
Thanks in advance guys.
Joseph
Last edit: 15 Mar 2016 17:46 by Josephking87.
16 Mar 2016 01:21 - 16 Mar 2016 01:22 #44626 by Deal57
Replied by Deal57 on topic Devo 10 with Apm 2.6
Here's a good thread with a couple of options. Good reading, too. Let us know if you have questions.
Last edit: 16 Mar 2016 01:22 by Deal57. Reason: Add link
16 Mar 2016 02:34 #44627 by Josephking87
Replied by Josephking87 on topic Devo 10 with Apm 2.6
Thanks for the reply!! I will check that link out.
Joe
23 Mar 2016 01:58 #45018 by Altun
Replied by Altun on topic Devo 10 with Apm 2.6
I have created the model below for the APM 2.6 and still using it;
Chanel 6 uses the gear and flight mode switches to select between 6 flight modes
Hope this helps...
name=APM
mixermode=Advanced
type=plane
[radio]
protocol=DSMX
num_channels=8
tx_power=150mW
[protocol_opts]
Telemetry=Off
[channel1]
template=simple
[mixer]
src=THR
dest=Ch1
curvetype=5point
points=-100,-50,0,50,100
smooth=1
[channel2]
reverse=1
template=expo_dr
[mixer]
src=AIL
dest=Ch2
scalar=75
curvetype=expo
points=40,40
[mixer]
src=AIL
dest=Ch2
switch=AIL DR1
curvetype=expo
points=40,40
[channel3]
reverse=1
template=expo_dr
[mixer]
src=ELE
dest=Ch3
scalar=75
curvetype=expo
points=40,40
[mixer]
src=ELE
dest=Ch3
switch=AIL DR1
curvetype=expo
points=40,40
[channel4]
reverse=1
template=expo_dr
[mixer]
src=RUD
dest=Ch4
scalar=85
curvetype=expo
points=40,40
[mixer]
src=RUD
dest=Ch4
switch=ELE DR1
curvetype=expo
points=40,40
[channel5]
template=complex
[mixer]
src=!GEAR1
dest=Ch5
scalar=-120
offset=20
curvetype=zero/max
points=0
[mixer]
src=FMODE1
dest=Ch5
scalar=40
usetrim=0
muxtype=add
curvetype=zero/max
points=0
[mixer]
src=FMODE2
dest=Ch5
scalar=80
usetrim=0
muxtype=add
curvetype=zero/max
points=0
[channel6]
template=simple
[mixer]
src=AUX5
dest=Ch6
curvetype=expo
points=0,0
[channel7]
reverse=1
template=expo_dr
[mixer]
src=MIX0
dest=Ch7
curvetype=fixed
[mixer]
src=MIX0
dest=Ch7
switch=MIX1
scalar=0
curvetype=fixed
[mixer]
src=MIX0
dest=Ch7
switch=MIX2
scalar=-100
curvetype=fixed
[channel8]
template=simple
[mixer]
src=RUD DR1
dest=Ch8
curvetype=min/max
points=0
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[trim5]
src=AUX4
pos=None
neg=None
[trim6]
src=AUX5
pos=None
neg=None
[timer1]
type=countdown
src=Ch1
time=180
[timer2]
src=Ch1
[datalog]
switch=None
rate=1 sec
[safety]
Auto=min
[gui-128x64]
V-trim=59,10,1
H-trim=5,59,3
V-trim=65,10,2
H-trim=74,59,4
Small-box=2,22,Ch5
Small-box=2,31,Ch1
Small-box=2,39,Timer1
Model=75,20
Battery=102,1
Toggle=4,10,0,3,0,RUD DR
Toggle=13,10,0,5,0,ELE DR
Toggle=22,10,0,4,0,AIL DR
Toggle=31,10,0,0,0,None
Toggle=40,10,0,0,0,None
TxPower=102,7
quickpage1=Telemetry monitor
03 Apr 2016 00:20 #45678 by Josephking87
Awesome thanks I'll give it a try! Does it show the throttle 0-100 by chance?
Joe
Time to create page: 0.220 seconds
