NFL024L Module Clarification Please
- Harlem
28 Mar 2016 14:00 #45334
by Harlem
NFL024L Module Clarification Please was created by Harlem
Hi, i am making a 'Devo 7e Mod NFL024 Made easy' video,, i am doing this as i go along as i believe being a newbie to mods and Devo gives me the opportunity to highlight the 'Must Knows' and pitfalls which many people after time (applies to all hobbies/sports/work) simply forget what they didn't understand and hence don't highlight such when learning others.
Anyways i gotta make sure it is 100% right for both my MOD and for the video.
Can i check,, if only ONE module is fitted to a Devo 7e, am i correct in saying the wires should be as pic attached?
Also, in the ini file i leave the 14 as 14, i do NOT change it to 13 as i have not soldered wires to TCK. Is this correct,
But i still remove semi colon in front of 'has NFL24 ' ?
Apologies for these newbie questions but remember, you were a newbie once:)
Thanks in advance Tony Harlem
- TomPeer
28 Mar 2016 16:29 #45345
by TomPeer
Replied by TomPeer on topic NFL024L Module Clarification Please
the yellow, red and pink lines go to the wrong connections, the color dots are correct.
TMS = A13 and TCK = A14. It does not matter which one you use. If you connect csn to TMS than it should be A13 and if you use TCK than it should be A14.
- RedSleds
28 Mar 2016 16:57 - 28 Mar 2016 17:05 #45346
by RedSleds
Replied by RedSleds on topic NFL024L Module Clarification Please
It's an nRF24L01, ......not NFL
...and, if the transceiver has power amplifiers (+PA +LNA) you need to un-comment the has_pa-nrf24l01 = 1 line as well
Last edit: 28 Mar 2016 17:05 by RedSleds.
Time to create page: 0.384 seconds
- NFL024L Module Clarification Please
