12s switch problem
- rdeviation
30 Mar 2016 17:07 #45450
by rdeviation
12s switch problem was created by rdeviation
HI
I have just installed deviation 4.0.1 plus the last nightly build. I was able to bind a receiver with no problem but when I program the switch outputs non of my three way switches work they just act like a two position switch. My sticks, sliders and knobs work fine with full control. any suggestions would be greatly appreciated.
You guys are doing great work, Thanks
Cheers
Cheers
- -=Hubi-Dirk=-
- rdeviation
30 Mar 2016 23:53 #45474
by rdeviation
Replied by rdeviation on topic 12s switch problem
I will give it a try, I think I may have been close to that at one point last night. Thanks Hudi will let you know
- rdeviation
31 Mar 2016 00:22 #45475
by rdeviation
I cannot get deadband under mix 1 and mix 2 it says linked? with no option to charge it as there are no arrows beside
(linked) to change the option. It does make a lot of sense though, I understand the principle of it now. Don't say anything to anybody but I almost went back to Devention...I just got my first Devo being the 12s the info on here is great I was able to Download and Upgrade with not a lot of problems. I had heard so many good things about the Deviation I think my first Devo had the stock firmware on it for about 5 Minutes. Would it matter at all if you did not have the latest factory firmware before I started, I was thinking no since I had formatted the drive anyway, but just incase please let me know
Thanks Again
Cheers
Thanks Again
Cheers
- -=Hubi-Dirk=-
31 Mar 2016 04:06 #45482
by -=Hubi-Dirk=-
you have to push on the "Mid-Rate" and the "Low-Rate" button, then "Linked" will gone and you can choose "Deathband", "3-Point", "Expo xx".....
Best
Dirk
Replied by -=Hubi-Dirk=- on topic 12s switch problem
rdeviation wrote: I cannot get deadband under mix 1 and mix 2 it says linked? with no option to charge it as there are no arrows beside
Best
Dirk
- rdeviation
31 Mar 2016 16:46 #45502
by rdeviation
HI
I figured it out just before your message but thanks so much. I have another
question but I will start a new thread
Time to create page: 0.134 seconds
- 12s switch problem
