Question about debug archive in nightly
20 Apr 2016 13:20 #46870 by lcc014
In nightly build archive, there is a debug-devo7e-v4.0.1-xxxx.zip. What is this "debug" archive for ? It contains a bunch of .elf files.
Thanks,
Ching-Ho Cheng
20 Apr 2016 13:38 #46871 by PhracturedBlue
Replied by PhracturedBlue on topic Question about debug archive in nightly
If you get a transmitter crash/reboot, you can provide the debug file and your error.log back to me and I may be able to see where in the code it crashed. Since the code changes every day, and we don't keep the builds around, I provide the debug file as part of the release so you can store it until you need it. The process is non-trivial and requires being familiar with ARM assembly, so it isn't something I've documented in the past.
20 Apr 2016 13:54 #46872 by lcc014
Replied by lcc014 on topic Question about debug archive in nightly
Thank you for the explanation. Do we have any sticky in this forum to explain the steps of capturing the debug file and error.log ?
20 Apr 2016 15:04 #46876 by PhracturedBlue
There is this:
www.deviationtx.com/wiki/reporting_bugs
Basically, there is no way to force capture these things. If your transmitter crashes, the errors.txt file will be generated on the transmitter (actually the file is always there, but will be re-generated when the tx crashes). On the Devo7e, these are of very limited value, but it is better than nothing.
20 Apr 2016 16:51 #46880 by lcc014
Great, thank you so much for the explanation and link.
Ching-Ho Cheng
Time to create page: 0.922 seconds
