JJrc X1 Devo 7e
- j0hnny5
22 May 2016 21:38 #49047
by j0hnny5
Replied by j0hnny5 on topic JJrc X1 Devo 7e
Do not use windows notepad , download Different note pad , that's where I was having trouble
- brett18
22 May 2016 22:39 #49054
by brett18
Replied by brett18 on topic JJrc X1 Devo 7e
Okay thanks, yes in usb I activated the mod to ( 1 enable-nrf24l01 = A13 has_pa-nrf24l01 = 1; ) I will try a different note pad. Do you suggest any?
- j0hnny5
22 May 2016 23:13 #49055
by j0hnny5
can't remember which notepads used but when you open the text it should be vertical text , I tryed note pad ++ and I had problems with it ,you just need a Basic Note pad
- j0hnny5
22 May 2016 23:15 #49056
by j0hnny5
Once you get it to bond let me now then there is one more last step
- dc59
23 May 2016 05:16 #49059
by dc59
Replied by dc59 on topic JJrc X1 Devo 7e
I use Notepad2 to edit ini file , no problem!
- C0ckpitvue 777
27 May 2016 04:26 #49344
by C0ckpitvue 777
Replied by C0ckpitvue 777 on topic JJrc X1 Devo 7e
Does anyone know how to recalibrate the Jjrc X1 with devo 7e.Tried to put both sticks to the bottom right corner like stock to no avail,any feedback is greatly appreciated.
- Deal57
27 May 2016 14:51 #49372
by Deal57
Replied by Deal57 on topic JJrc X1 Devo 7e
For the calibration only, did you try adjusting your trim by 10-20 clicks? Do you have any subtrim or mixer settings that might be causing the outbound channel values to be higher than -100%?
- C0ckpitvue 777
27 May 2016 15:10 #49374
by C0ckpitvue 777
This is the model ini I am using,don't really know to much about the mixer still learning.
name=JJRC X1
permanently_timer=10
mixermode=Advanced
type=multi
[radio]
protocol=HonTai
num_channels=11
tx_power=150mW
[protocol_opts]
Format=JJRCX1
[channel1]
template=simple
[mixer]
src=AIL
dest=Ch1
[channel2]
template=simple
[mixer]
src=ELE
dest=Ch2
[channel3]
min=-130
template=simple
[mixer]
src=THR
dest=Ch3
[channel4]
template=simple
[mixer]
src=RUD
dest=Ch4
[channel5]
template=simple
[mixer]
src=FMODE0
dest=Ch5
curvetype=expo
points=0,0
[channel7]
template=simple
[mixer]
src=Virt1
dest=Ch7
curvetype=expo
points=0,0
[channel8]
template=simple
[mixer]
src=Virt2
dest=Ch8
curvetype=expo
points=0,0
[virtchan1]
name=Photo
template=simple
[virtchan2]
name=Video
template=simple
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
step=5
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
value=2,0,0
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
value=-3,0,0
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[trim5]
src=Virt1
pos=Up
step=193
value=-100,0,0
[trim6]
src=Virt2
pos=Down
neg=TRIMRV-
step=193
value=-100,0,0
[timer2]
type=countdown
time=720
[safety]
Auto=min
[gui-128x64]
V-trim=59,10,1
H-trim=5,59,3
V-trim=65,10,2
H-trim=74,59,4
Small-box=2,22,Ch3
Small-box=2,31,Timer1
Small-box=2,40,Timer2
Model=75,20
Battery=102,1
Toggle=4,10,0,3,0,None
Toggle=13,10,0,5,0,None
Toggle=22,10,0,4,0,None
Toggle=31,10,0,0,0,None
Toggle=40,10,0,0,0,None
TxPower=102,7
quickpage1=Telemetry monitor
name=JJRC X1
mixermode=Advanced
type=multi
[radio]
protocol=HonTai
num_channels=11
tx_power=150mW
[protocol_opts]
Format=JJRCX1
[channel1]
template=simple
[mixer]
src=AIL
dest=Ch1
[channel2]
template=simple
[mixer]
src=ELE
dest=Ch2
[channel3]
min=-130
template=simple
[mixer]
src=THR
dest=Ch3
[channel4]
template=simple
[mixer]
src=RUD
dest=Ch4
[channel5]
template=simple
[mixer]
src=FMODE0
dest=Ch5
curvetype=expo
points=0,0
[channel7]
template=simple
[mixer]
src=Virt1
dest=Ch7
curvetype=expo
points=0,0
[channel8]
template=simple
[mixer]
src=Virt2
dest=Ch8
curvetype=expo
points=0,0
[virtchan1]
name=Photo
template=simple
[virtchan2]
name=Video
template=simple
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
step=5
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
value=2,0,0
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
value=-3,0,0
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[trim5]
src=Virt1
pos=Up
step=193
value=-100,0,0
[trim6]
src=Virt2
pos=Down
neg=TRIMRV-
step=193
value=-100,0,0
[timer2]
type=countdown
time=720
[safety]
Auto=min
[gui-128x64]
V-trim=59,10,1
H-trim=5,59,3
V-trim=65,10,2
H-trim=74,59,4
Small-box=2,22,Ch3
Model=75,20
Battery=102,1
TxPower=102,7
- Deal57
27 May 2016 16:31 - 27 May 2016 16:32 #49381
by Deal57
Good, it looks like the mixers aren't doing anything with the rudder. i don't have the X1 (kinda like to get one!) so I can't tell if using the min -130 on the throttle makes a difference, but I don't expect it would.
Look at the channel monitor and verify that both channels 3and 4 are sending -100 when you put the sticks into that position. If not, you can try calibrating your Devo sticks, and if that doesn't work, I've seen the use of trim or subtrim to fix this...
By the way, are you testing these settings with the blades off (don't ask me why I ask...)?
Last edit: 27 May 2016 16:32 by Deal57.
- Deal57
27 May 2016 16:35 #49382
by Deal57
And if you haven't yet, take a look at this thread:
www.deviationtx.com/forum/protocol-devel...-x1-capture?start=60
- C0ckpitvue 777
27 May 2016 17:19 #49386
by C0ckpitvue 777
Thanks deal57,I greatly appreciate your feedback and prompt response.Yes the props are off while trying to calibrate but the X1 is not armed.
- brett18
27 May 2016 22:05 #49404
by brett18
Im still having trouble getting my devo to bind to my x1. It's weird, I'm not sure if some solders are bad or what. But I can access the Hontai protocol and try to initiate the bind but nothing happens, the lights on the x1 continue to blink and it does not sounds off. I tried using multiple different notepads and still nothing. If anyone knows where I went wrong it would be greatly appreciated. However, if I do get it to bind sometime or another, what is the arming sequence, anyone??
- C0ckpitvue 777
27 May 2016 22:14 #49405
by C0ckpitvue 777
Did you scroll down to the bind option and press ent on hontai to choose the Jjrc X1 option?
- brett18
27 May 2016 22:45 #49408
by brett18
Yes did that too, (found the jjrrc x1 format under hontai protocol) still wont bind.
- C0ckpitvue 777
27 May 2016 23:25 #49409
by C0ckpitvue 777
Copy and paste the jjrcx1 file to that folder and it arms with the switch the one furthest to the right.
- C0ckpitvue 777
27 May 2016 23:26 #49410
by C0ckpitvue 777
The file I pasted on top.
Time to create page: 0.276 seconds
- JJrc X1 Devo 7e
