DIY 433mhz long range system
31 Aug 2016 09:38 #53321 by nanoflyer
Replied by nanoflyer on topic DIY 433mhz long range system
Success
My ULRS MINI TX works.
It took me half an hour soldering and tada, flashed and ready.
I flashed it with lrsng since my receivers (Brotronics sub micro rx) are not supported in flip flaps ulrs.
Thanks Cereal_killer for the design.
06 Sep 2016 06:47 #53538 by vampy
Replied by vampy on topic DIY 433mhz long range system
I'm new to this 433 MHz system.
I ordered all parts, will solder them as soon as they are here.
Just one question for clarification. Can I connect to ppm pins of the 433 MHz pcb a flysky ia6b receiver in interaction with goebish afhd2a devo 7e firmware (ibus to ppm setting). And at the same time serial from the pcb to a Smartphone/Laptop.
Or do I need to connect the 433 MHz system with a ppm wire to the devos trainer port?
Second 433 MHz system is of course in the copter.
Thanks in advance.
Time to create page: 0.384 seconds
