Help with V120DO2S gyro problem
- shwmae
02 Jul 2016 18:44 - 02 Jul 2016 18:50 #51258
by shwmae
Help with V120DO2S gyro problem was created by shwmae
So I'm trying to set up my V120D02S with Deviation for the first time. I'm using a Devo 8 TX.
No matter what I try, I cannot get the swashplate levelling to operate. The head holding gyro is working fine and is keeping the tail rotor locked in but nothing is happening with the swash as I tilt the heli over.
I've got the Gyro sense channel set to AUX2/Ch7 and the values at 70% but I think this only effects the head holding gyro as dropping the value below 51% turns it and the red LED on the RX off.
I know from experience that the swash levelling doesn't kick in until throttle is applied and I've tried running the motor up but still hasn't cured the problem.
Any ideas guys? it's driving crazy?
The heli flew fine the last time I used it with the stock Walkera firmware and I haven't changed anything on it since.
Last edit: 02 Jul 2016 18:50 by shwmae.
- ThomasC
03 Jul 2016 08:33 #51271
by ThomasC
Replied by ThomasC on topic Help with V120DO2S gyro problem
Possibly you have accidentially switched the WK/ADJ dip switch to ADJ? This turns your gyros off...
Time to create page: 0.347 seconds
- Help with V120DO2S gyro problem
