Devo 10 DSM2
- DJDavid33
27 Jul 2016 13:10 #52208
by DJDavid33
Devo 10 DSM2 was created by DJDavid33
Hello I received my vien "devo 10" I install "deviation 5.0.0"
to run the "DMS2" how to set up the file "hardware.ini"?
I half as below.
it must also put the "has_pa-cyrf6936 = 1"?
and to put in my french devo 10 how to thank you
[Modules]
; there is no need to enable the unit UNLESS cyrf6936
; it is wired to an alternate port. It is automatically Enabled Otherwise
enable-cyrf6936 = B12
; has_pa-cyrf6936 = 1
; enable-a7105 = A13
; has_pa-a7105 = 1
; enable-CC2500 = A14
; has_pa-CC2500 = 1
; enable-nRF24L01 = A14
; has_pa-nRF24L01 = 1
; enable-Multimod = A13
I half as below.
[Modules]
; has_pa-a7105 = 1
; has_pa-CC2500 = 1
- Cereal_Killer
27 Jul 2016 13:18 #52209
by Cereal_Killer
Replied by Cereal_Killer on topic Devo 10 DSM2
To run dsm there are NO CHANGES needed, just power it on and go! It's impossible (in a standard or nightly build) to disable the CYRF module so you don't need to turn it in either...
- DJDavid33
Time to create page: 0.295 seconds
- Devo 10 DSM2
