Devo 7E with A7105 and hacked flysky IA6 receiver
- vampy
24 Aug 2016 00:07 #53054
by vampy
Devo 7E with A7105 and hacked flysky IA6 receiver was created by vampy
Sorry if it is a common question.
I would like to know if it possible to get telemetry rx voltage data from battery to the display with a hacked flysky IA6 receiver.
24 Aug 2016 05:51 #53062
Replied by mwm on topic Devo 7E with A7105 and hacked flysky IA6 receiver
Not with the existing code. Our flysky implementation doesn't support telemetry. If I understand correctly, this is a property of the protocol, and the flysky protocol that has telemetry is different from what we implement.
- Fernandez
24 Aug 2016 09:41 #53071
by Fernandez
Replied by Fernandez on topic Devo 7E with A7105 and hacked flysky IA6 receiver
Check the work of the Master "Goebish" in this topic:
www.deviationtx.com/forum/protocol-devel...i10-i6-it4?start=300
It is still in test build, not in nighltlies, but the firmware posted in the last pages works good Incuding telemetry of RX Volt and RSSI.
You might need to flash the Rx using ST Link, to latest version, or ask someone to do it from its i10 radio.
The IA6b can be modded also to send out pack voltage instead of the 5v regulated Rx voltage.
Flysky Ibus Telemety Sensors are not yet implemented.
Time to create page: 0.198 seconds
- Devo 7E with A7105 and hacked flysky IA6 receiver
