cyrf6936 stock module
11 Sep 2016 08:46 #53784 by hydro
cyrf6936 stock module was created by hydro
Is it possible to switch off the stock devo module? .It is automaticaly i found when i turn on the power but can i swith it of??
I am modding a devo 12s with a cc2500 module .When i am turning on the power then de i get a warning the cyrf6936 module can not be found.
When i enable the cc2500 module then i get the warning that both modules can not be found.
Is it possible that i have to flash a nightly build version to solve the problem?
I am still uncertain what the problem is
albert
11 Sep 2016 12:01 #53788 by bianchifan
Replied by bianchifan on topic cyrf6936 stock module
I do not know 12s I've that prob with my 7e ultimate/256k version
Missing Modules: CYRF9636
With the latest nitely from mid July this error doesn't appear any more
11 Sep 2016 22:57 #53801 by Cereal_Killer
Replied by Cereal_Killer on topic cyrf6936 stock module
hydro wrote: Is it possible to switch off the stock devo module? .It is automaticaly i found when i turn on the power but can i swith it of??
With any build that you've downloaded no it's not possible. If you are able to do your own builds then technically yes you could but even nightly builds, even people's private test builds that are in the test build sections no none of those will allow you to switch off the devo module just simply because why would they...
Time to create page: 0.212 seconds
