F12E Multi Module
06 Jan 2017 03:45 #57574 by Artus
Replied by Artus on topic F12E Multi Module
I my F12E i am the "normal" pins (TMS,TCK,3,3V GND, MISO, MOSI, SCK) and they are working well.
I am edditing the hareware.ini - make a new devo.fs file with "builds" and transfer this file to the F12E via USB.
Align TREX 100 (3) Hubsan Q4
Walkera QRX 350 PREMIUM
08 Jan 2017 21:19 #57715 by djgaby
Replied by djgaby on topic F12E Multi Module
Could you take some photos of the connections of your f12e? And what devention version do you have installed? thank you very much!!!!
09 Jan 2017 01:14 #57721 by victzh
Replied by victzh on topic F12E Multi Module
Devention is the original name of the line of TXs, Deviation is the third party firmware for this line (not only now).
09 Jan 2017 06:18 #57728 by djgaby
Sorry, could you take some pictures of the wiring? And what version of deviation do you have?
09 Jan 2017 06:45 #57730 by Bonemyster
Replied by Bonemyster on topic F12E Multi Module
The wiring for the f12e 3 in 1 module is the same as the devo 10 wiring.
09 Jan 2017 09:15 #57740 by djgaby
If all but one cable goes the same, the cable that is connected to CS_2401 does not understand where it is connected in the Devo f12e
09 Jan 2017 13:46 #57745 by Bonemyster
Weve already answer this question on this forum, the nrf2401 goes to B3 with a space after 3 on the stm32f103 chip or to B10. Ive used either one in the past. The picture with the pin above the chip being used is B10 and the one with the pin below the chip is B3 if i rememer the pin names correctly. You can use either one.
09 Jan 2017 13:50 - 09 Jan 2017 13:57 #57746 by Bonemyster
B3 is pin number 12 comming from the bottom right conner of the Stm32 chip. Count from your right to left.
Last edit: 09 Jan 2017 13:57 by Bonemyster.
09 Jan 2017 13:51 #57747 by Bonemyster
If after this you still have problems then reread the first page of this forum.
09 Jan 2017 23:02 #57763 by djgaby
Thank you very much, I will try to connect it as in the photo you sent
14 Mar 2017 04:52 - 14 Mar 2017 07:57 #60178 by Fuyingbro
Replied by Fuyingbro on topic F12E Multi Module
I have installed the 4-in-1 module, nightly build 5.0.0f9f5188. I simply have not found in the forums after hours of hours of looking of what the pins are for tms and tck. I thought they were the same as DEVO 10, but I either get a constant restart or modules not enable. I saw your post in about b3 and b10. I have connected to B3 and set in hardware.ini as B3(space). Maybe I am not suppose to use TMS and TCK. I just can't find any diagrams on those being the correct connection points for the 4-in-1 although came across a comment of using tms and tck. But no photos of it actually being the correct ports and what the ports are called in Hardware.ini. Could you please assist.
Edit: This is on a F12E. I know the forum is about the F12E, but found a few forums where someone asks about another TX
EDIT!!!! I solved it one my own. I changed how I was searching the forums. I found my mistake. When someone showed an example of putting B3_for A13 I actually changed mine to that instead of doing as the person was saying and use it only as an example.
Found correct pin outs here. www.deviationtx.com/forum/7-development/...dule?start=940#55157
Last edit: 14 Mar 2017 07:57 by Fuyingbro. Reason: Solved my own issue.
Time to create page: 0.884 seconds
