TX chip from broken tx
22 Sep 2016 03:46 #54122 by Josegonzalez1985
TX chip from broken tx was created by Josegonzalez1985
Well I was trying to see if the tx board in my udi tx was one I could use in my devo and I guess I wasent careful enough cuz I snapped the solder pads right off the main board but the tx module is in perfect condition, does anyone know if a ABE-2.4GPA-3A marked chip is any use to me in my devo 10
22 Sep 2016 16:31 #54128 by HappyHarry
Replied by HappyHarry on topic TX chip from broken tx
it depends from which udi model the tx is from, I know some use the beken rf chip though
22 Sep 2016 21:02 #54134 by Deal57
Replied by Deal57 on topic TX chip from broken tx
It sure looks like it's in the NRF24L01 family (but which one?) and it looks to me like it has a power amp. The connections are labeled the same as the deviation-supported transmitter modules. If you're up to it, you can wire it up and see if any of the protocols work.
23 Sep 2016 12:33 #54162 by Josegonzalez1985
Replied by Josegonzalez1985 on topic TX chip from broken tx
HappyHarry wrote: it depends from which udi model the tx is from, I know some use the beken rf chip though
It was from a u818a wifi, if I can't get a transmitter for it I'm gonna cannibalize it for a micro build, but I can see the rx chip soldered to the board I wonder if I could make it use a different rx
23 Sep 2016 12:34 #54163 by Josegonzalez1985
Deal57 wrote: It sure looks like it's in the NRF24L01 family (but which one?) and it looks to me like it has a power amp. The connections are labeled the same as the deviation-supported transmitter modules. If you're up to it, you can wire it up and see if any of the protocols work.
I don't have anything that could fly using that set ofor protocols, unless you mean see if one of the protocols could run the udi
23 Sep 2016 13:05 #54167 by Cereal_Killer
Replied by Cereal_Killer on topic TX chip from broken tx
Can you read the writing on the black square QFN chip for us? The "ABE-2.4GPA-3A" silk screen print in is the name of the module (and means nothing except to ID that module to the maker), not the chip it's self that we need...
23 Sep 2016 13:09 #54169 by Josegonzalez1985
Cereal_Killer wrote: Can you read the writing on the black square QFN chip for us? The "ABE-2.4GPA-3A" silk screen print in is the name of the module (and means nothing except to ID that module to the maker), not the chip it's self that we need...
I'll look when I get home
23 Sep 2016 23:54 #54190 by Josegonzalez1985
I think this is what you were talking about cereal
2402e
4547.1
Uf1537
24 Sep 2016 13:52 #54213 by Deal57
That chip is a power amp, and it is often used with the NRF24L01 chip. But with the number of similar and fake clone modules there isn't any way to tell if this is really any particular one, and most don't exactly perform the same. So it may work just fine, or the distance may be limited, or you may see dropouts.
If you're flying cheap small quads, then it's probably ok, but I wouldn't use it for anything powerful enough to get away and do damage.
24 Sep 2016 15:40 #54215 by Josegonzalez1985
Could you show me on my original photos what chip you want me to read, I would like to learn all I can about this as I can, and one of the biggest things to learn is how to properly identify. Any knowledge on the subjects of these modules and how to do what with them is much appreciated
24 Sep 2016 17:02 #54220 by HappyHarry
the udi u818a uses a beken 2421 rf chip, it's mostly nrf24 compatible but I don't think it's 100%
26 Sep 2016 20:56 #54307 by victzh
Replied by victzh on topic TX chip from broken tx
Beken is supported by the current protocol set - people usually copy intialization from some other protocol, so it propagated over the protocol set.
30 Sep 2016 22:25 #54455 by Josegonzalez1985
So do you think I could use it to bind a cheerson cx-10, I'm picking up a devo 7 today and would like to set it up for my daughters quad
01 Oct 2016 00:14 #54456 by Deal57
The Walkera Devo 7 is NOT the same as a Devo 7e. The Devo 7 cannot run Deviation.
01 Oct 2016 13:30 #54464 by Josegonzalez1985
Yeah I found that out when I got home, guess I should have read up before getting my hopes up. I bought a kit off someone so it's not a total loss but damn why won't they make deviation for it. They say they won't because e it doesn't support usb but you can upgrade firmware using the up02 dongle so I don't see why they can't at least make it use multi protocols mode
Time to create page: 0.710 seconds
