UFO Venture
- Bisky
14 Oct 2016 18:13 - 14 Oct 2016 18:14 #54921
by Bisky
Devo F7 XMS + 4in1 module
UFO Venture was created by Bisky
Does anyone know witch protocol this uses? i made some pictures of the transmitter and receiver.
www.google.si/search?q=ufo+venture&espv=...rc=CIjEdcxT12jWxM%3A
Last edit: 14 Oct 2016 18:14 by Bisky.
- ajtank
16 Oct 2016 15:03 #55014
by ajtank
Replied by ajtank on topic UFO Venture
The transceiver chip has 16 pins so it could be a XN297L. Try CX10 protocol.
- Bisky
18 Oct 2016 19:12 - 18 Oct 2016 19:25 #55108
by Bisky
Thanks, but it does not work.
I opend up the drone, its a LT5910...
Replied by Bisky on topic UFO Venture
ajtank wrote: The transceiver chip has 16 pins so it could be a XN297L. Try CX10 protocol.
Last edit: 18 Oct 2016 19:25 by Bisky.
- HappyHarry
18 Oct 2016 20:30 #55112
by HappyHarry
Replied by HappyHarry on topic UFO Venture
the LT5910 is just an mcu with an nrf/xn297 compatable rf chip built it, these can be paired with either an nrf or an xn297 in the transmitter. for instance the eachine e010 uses a setup similar to that, a combined mcu/rf chip on the quad and an xn297lbw on the transmitter
- ajtank
19 Oct 2016 05:38 #55127
by ajtank
Try also Bayang, CG023, H8_3D, Hontai, MJXq.
If not ok then you need to post the SPI capture and request to build a new protocol.
- Bisky
19 Oct 2016 16:39 #55158
by Bisky
None of the above protocols worked, tried all sub options
Pretty sure I can't do SPI capture...
Thanks any ways...
Thanks any ways...
Time to create page: 0.742 seconds
- UFO Venture
