Aux knobs and mix switch 5.0
26 Oct 2016 03:17 #55388 by Yotabeast505
Aux knobs and mix switch 5.0 was created by Yotabeast505
I installed the new 5.0 on my Devo10. Now the mix switches.. well ALL the 3 position switches only act as a 2 position and the knobs do nothing at all... PLEASE HELP i cant figure out how to trim them to work as a 3 position switch and i need the aux knobs to control my camera gimble. Using on Naza m v2 .
26 Oct 2016 08:49 - 26 Oct 2016 09:57 #55396 by ajtank
Replied by ajtank on topic Aux knobs and mix switch 5.0
The output of the flip switches is either 100% or -100% but you can apply scalar in the mixer to achieve 100%, 0%, -100% output.
You can also use trim buttons to get 100/0/-100 output. Here is my case and I have used 2 different ways to acheive so.
Actually Devo 10 already comes with two pots which can deliver -100/0/100. I don't quite understand what your actual problem is.
Last edit: 26 Oct 2016 09:57 by ajtank.
26 Oct 2016 18:57 #55424 by Cereal_Killer
Replied by Cereal_Killer on topic Aux knobs and mix switch 5.0
You can also use 3 mixers... so many ways to do a 3-pos switch so check the manual and choose what you like best (i use 3 fixed mixers, one set to each individual switch but other ways arnt wrong! Deviation is just so powerful you can solve problems multiple ways).
For the pots not showing up first check devo sees the inputs (chanel monitor then press R), pots are AUX4 & AUX5. If they show there then again you just need some basic mixer setup.
If theyre not showing try calibrating the sticks in transmitter menu
27 Oct 2016 06:14 #55430 by Yotabeast505
Replied by Yotabeast505 on topic Aux knobs and mix switch 5.0
Thank you! I didnt turn them when i calibrated the tx.. the aux knobs are working great. Went into the complex and made 3 mix for the toggle switches. They work great now. I was using the OLD version of deviation like the first one that came out lol so it was simpler. Thanks for all your help
02 Nov 2016 00:00 #55592 by Yotabeast505
Used 3 mixes and it worked out great! thank you guys for all your help. Calibrating the TX also made the knobs work. i guess i forgot to turn them the first calibration. Thank you everyone!
Time to create page: 0.409 seconds
