Devo 6 vs Devo 6s vs Devo 7e
06 Nov 2016 17:27 #55745 by jackp311
Devo 6 vs Devo 6s vs Devo 7e was created by jackp311
Hi All!
I purchased a Devo 7e from eBay. I got a Devo 6, instead.
What is the difference between a 6 and a 6s? I can't seem to find a plain 6 online.
Which is the best transmitter to use for Deviation?
What about transmit power? Can I do a diode mod on Devo 6?
06 Nov 2016 19:29 - 06 Nov 2016 19:38 #55752 by karl.h
Replied by karl.h on topic Devo 6 vs Devo 6s vs Devo 7e
Turn the box around, they use the same box. I was also like wtf when i got my 7e. Although with them sharing the box I guess it's possible someone screwed up and sent you a radio that is 2-3 times the price.
If you really did get a 6 (most likely a 6s), congrats it's a better radio. It's full power out of the box so no need for mod.
www.deviationtx.com/wiki/transmitter/devo6
www.deviationtx.com/wiki/transmitter/devo7e
Last edit: 06 Nov 2016 19:38 by karl.h.
07 Nov 2016 09:56 #55770 by RoGuE_StreaK
Replied by RoGuE_StreaK on topic Devo 6 vs Devo 6s vs Devo 7e
The "S" was marketed as an update with telemetry, but I never have figured out if there is a physical difference between the S and non-S modules, which are used in the 6, 8, 10 and 12, or whether it was purely software related.
I personally have a "6" branded one.
6 is FAR the better than the 7E, the only negative being sunlight readability, which a high-contrast theme can help with (but not totally eliminate). More powerful processor, full-power socketed module, more switches in stock form and even more in modified form. Note however that though the module is full power, it is not tied to a gained antenna, so that's one thing that can be upgraded (for a couple of bucks) to give more range.
6/6S is getting ultra-rare now so you REALLY got lucky.
07 Nov 2016 21:49 #55782 by jackp311
Replied by jackp311 on topic Devo 6 vs Devo 6s vs Devo 7e
It was a 7e - I was looking at the wrong side of the box.
Whoops.
Time to create page: 0.043 seconds
