Maximum voltage walkera receivers
19 Dec 2016 20:26 #57014 by julianholzner
Maximum voltage walkera receivers was created by julianholzner
Hi Guys,
I fly my deviation system with the original walkera receivers like RX701, RX601 and RX1202.
Does anyone of you know if they support the high voltage setup of 7.4volt?
Did anyone out there test it?
19 Dec 2016 20:40 #57015 by FDR
Replied by FDR on topic Maximum voltage walkera receivers
The specification says 4.8V - 6V, however they do operate from 1S as well, at least the RX601 I tried.
I wouldn't pass far over 6V...
27 Dec 2016 20:09 #57268 by jejeg
Replied by jejeg on topic Maximum voltage walkera receivers
Works with lifes (7,2V) without regulator .:)
28 Dec 2016 06:38 - 28 Dec 2016 06:39 #57280 by julianholzner
Replied by julianholzner on topic Maximum voltage walkera receivers
Thanks for your input.... I know the manual says 4.8v-6v but somethimes it works fine going over that.
Jejeg I think I will give it a try with hv bec and fixed 7,4v, thats not much over your tested 7,2v.
I will order a second rx601 and keep you updated about the testing result.
Greetings from italy
Last edit: 28 Dec 2016 06:39 by julianholzner.
01 Jan 2017 18:25 #57434 by jejeg
Ok .:)
Happy new year .
14 Feb 2017 16:14 - 14 Feb 2017 16:15 #59129 by julianholzner
Hi Guys,
just to let you know, I am using now a YEP LV ESC with regular 7,4V output on my cheap RX601 receiver combined with 4x SV1250MG servos.
Till jet no problem found!!
Everything works fine with 7,4V.
Cheers
Last edit: 14 Feb 2017 16:15 by julianholzner.
15 Feb 2017 18:49 #59161 by jejeg
Super ...:)
Time to create page: 0.040 seconds
