Adjusting a helicopter with Devo 10
- dg0csg
26 Dec 2016 17:34 #57259
by dg0csg
Adjusting a helicopter with Devo 10 was created by dg0csg
Hi there!
Please, can you help me?
I got a question:
My Hardware is a Devo 10 with Deviation 5.0, a paddle helicopter with an 8-channel Walkera Receiver. The helicopter has 4 servos. Now my question is, how do I have to adjust my Devo 10, so that everything works out correctly?
So far I got everything connected, but unfortunately the servos doesn´t work correctly. The wobble plate doesn´t go up when I accelerate, but it should go up...
It would be awesome, if someone can help me and answer my question above to solve my Problem.
Thank you very much! - Greetings from Germany -
I got a question:
- Artus
26 Dec 2016 18:32 #57261
by Artus
Align TREX 100 (3) Hubsan Q4
Walkera QRX 350 PREMIUM
Replied by Artus on topic Adjusting a helicopter with Devo 10
I am not sure - i dont know your experince about mixer - but i think you have to adjust first the kind of shwash type you have - (model setup - model type Heli - then enter button)
Try this without props first
But the other question is - what kind of flight controller do you use ?
- Thomas.Heiss
27 Dec 2016 18:30 #57267
by Thomas.Heiss
Replied by Thomas.Heiss on topic Adjusting a helicopter with Devo 10
Heli issues in release 5.0:
www.deviationtx.com/forum/6-general-disc...eased?start=60#53953
I played around with CCPM120 flybar.
You are probably the first one with 4 servos and 90 degree setting
Try it and see if this stuff also applies to the CCPM heli mixing 90 code (while it definitely does for 120).
CCPM mixing 120/90 is very buggy in the standard GUI and you can only workaround it at the moment by MANUALLY editing the model.ini file.
So you better choose the advanced GUI route...or....live with the drawbacks
- Adjusting a helicopter with Devo 10
