Max number of models
- Sero
- RC-addicted
28 Jan 2017 20:50 #58494
by Sero
Max number of models was created by Sero
What is the maximal number of models that can be stored on a Devo 6s? I am at number 100 and seem unable to add another one...
- HappyHarry
28 Jan 2017 22:42 #58506
by HappyHarry
Replied by HappyHarry on topic Max number of models
i didn't know there was a limit bar flash space? but i may be wrong
- Arnold
28 Jan 2017 23:24 #58508
by Arnold
The Deviation User Manual, in the Overview section says,
This can be limited by storage space available on the radio and the sizes of the various model configuration files being stored.
Replied by Arnold on topic Max number of models
Sero wrote: What is the maximal number of models that can be stored on a Devo 6s? ...
Deviation can store up to 255 different models ...This can be limited by storage space available on the radio and the sizes of the various model configuration files being stored.
- Sero
- RC-addicted
28 Jan 2017 23:52 #58510
by Sero
Replied by Sero on topic Max number of models
There is still space left, but no matter how I try to add another one, 100 models seems to be the maximum...
- Arnold
29 Jan 2017 00:36 - 29 Jan 2017 00:42 #58511
by Arnold
Since you say there is space available on the radio, try duplicating a model file on the radio and then try to edit and re-save it back to the radio.
If that fails, I think my last resort would be to format the Devo (using the installation tool of your choice - not by using the computer's tools) and reinstall deviation.
* It should be obvious that you would want to back up those items on the radio that you want to be sure to save. *
Last edit: 29 Jan 2017 00:42 by Arnold.
- Sero
- RC-addicted
29 Jan 2017 00:47 #58512
by Sero
My second 6s is the same, so this seems to be normal behavior.
- Arnold
29 Jan 2017 01:05 #58514
by Arnold
6S X Two!
Lucky guy!
Lucky guy!
29 Jan 2017 05:21 #58518
Replied by hexfet on topic Max number of models
Took a look at the code and there is a hard-coded limit of 100, for no good reason that I could see. I've made a test build that increases the limit to 255. There still might be an issue if number of models plus number of layouts is more than 255 and you try to load a layout, but hopefully not
Actually don't see why it couldn't go past 255 if necessary.
Can't get the test build upload link to work. A devo6 dfu is attached.
- Fernandez
29 Jan 2017 16:25 #58533
by Fernandez
Replied by Fernandez on topic Max number of models
More than 100 models, Wow that's a serious "Deviation Gold Member".
30 Jan 2017 05:20 - 30 Jan 2017 05:21 #58546
Would you try to upload it again?
PB has fixed the upload:
Replied by FDR on topic Max number of models
hexfet wrote: Can't get the test build upload link to work. A devo6 dfu is attached.
the user-upload code should auto-update, but if it does not, download the latest copy manually. you need 0.9.6
Last edit: 30 Jan 2017 05:21 by FDR.
02 Feb 2017 00:46 #58635
Thanks FDR. No need for a test build now as the change has been merged and is in the nightly build.
06 Feb 2017 14:47 - 06 Feb 2017 17:08 #58820
Replied by vlad_vy on topic Max number of models
It doesn't work well. Transmitter reboot with any attempt to load new model if number of models >130~150.
Problems:
1. I think that model_count() function work too slow with large number of models and we get reboot by timeout.
2. We can't have 255 model limit, since main screen "Layout" templates list show templates and models: templates + models <=255. More real models limit will be about 200.
If change num_models = model_count(); to num_models = count_files("models", ".ini", NULL) - 1;, it work well, but it's not strict verification: we can skip model files, have arbitrary names and so on.
I think will be better to revert commit "Increase maximum number of model files from 100 to 255".
Problems:
Last edit: 06 Feb 2017 17:08 by vlad_vy.
07 Feb 2017 06:26 - 07 Feb 2017 06:29 #58849
We can use modified model_count():
It doesn't check/verify every model file, but missing model files and >200 model files only. In such case user will get empty models list. It work fine with any number of model files (<= 255).
int model_count()
int num_models = count_files("models", ".ini", NULL) - 1;
if(num_models > 200)
num_models = 200;
//check if model file is missing or >200 model files
sprintf(tempstring, "models/model%d.ini", num_models + 1);
if (fexists(tempstring))
num_models = 0;
return num_models;
}It doesn't check/verify every model file, but missing model files and >200 model files only. In such case user will get empty models list. It work fine with any number of model files (<= 255).
Last edit: 07 Feb 2017 06:29 by vlad_vy.
07 Feb 2017 07:20 #58854
The problem is that if you don't check all the model files in the loadable range, then it will fail when it wants to load a missing file.
Have you tried if the "fexists" is faster then the "fopen/fclose" was in the original implementation?
Like this:
Like this:
int model_count()
int num_models;
for (num_models = 1; num_models <= 255; num_models++) {
sprintf(tempstring, "models/model%d.ini", num_models);
break;
num_models--;
return num_models;
}- vlad_vy
07 Feb 2017 08:14 - 07 Feb 2017 08:16 #58859
"fexists" do exactly the same things, but takes less space. But anyway, I can't fit changed code to devo7e v5.0.0 build, overflowed by 4 bytes.
I've tested with missing file, it works but can't be saved. With check, if any model file skipped you will get empty models list.
Last edit: 07 Feb 2017 08:16 by vlad_vy.
07 Feb 2017 09:23 - 07 Feb 2017 17:53 #58864
If model files will be numbered: modelXXX.ini ("model001.ini" to "model200.ini") model_count() function can be:
int model_count()
int num_models = 0;
if (FS_OpenDir("models")) {
char filename[13];
int type;
while((type = FS_ReadDir(filename)) != 0) {
if (type == 1 && strncasecmp(filename + strlen(filename) - 4, ".ini", 4) == 0) {
if(strncasecmp(filename, "default.ini", 11) != 0) {
num_models++;
sprintf(tempstring, "model%03d.ini", num_models);
if(strncasecmp(filename, tempstring, 12) != 0) {
num_models--;
break;
if(num_models >= 200) {
num_models = 200;
break;
FS_CloseDir();
return num_models;
Last edit: 07 Feb 2017 17:53 by vlad_vy.
07 Feb 2017 10:44 #58865
That naming convention would be better by any means, but that would break the compatibilit, and the users had to rename all of their files, which is not a good thing...
- Fernandez
07 Feb 2017 11:10 - 07 Feb 2017 11:12 #58866
by Fernandez
if we can group models, or store in folders would that help? That way can keep more organized, go to heli >select the heli.
also usefull if we could add annotation in the label. Model001_SuperCP_Walkera etc,
would make way more easy to find and or exchange model files.
Last edit: 07 Feb 2017 11:12 by Fernandez.
- Moeder
07 Feb 2017 11:26 #58867
by Moeder
Replied by Moeder on topic Max number of models
This would for sure not fit on the 7e.
Vlad,just make the code change to 255 an option not available on 7e...I'd say any user with 100+ models won't stick with a 7e
07 Feb 2017 11:38 #58868
The minimalist filesystem used in deviation can't create, copy or rename files, only can use the existing ones, that's why they are named as modelXX.ini...Fernandez wrote: if we can group models, or store in folders would that help? That way can keep more organized, go to heli >select the heli.
Time to create page: 0.376 seconds
- Max number of models
