Devo F12E Installation confusion
23 Mar 2017 14:32 #60620 by Quietsch
Replied by Quietsch on topic Devo F12E Installation confusion
Ok, thank you! I hope i will get this sooner than i will have assembled the new racer :)
If someone got an idea what i did wrong pls provide it, it would be cool if i could import new models just like that... :)
23 Mar 2017 14:51 #60621 by FDR
Replied by FDR on topic Devo F12E Installation confusion
Have you already tried to extract Diggidy's devo.fs?
23 Mar 2017 15:01 - 23 Mar 2017 15:14 #60622 by Quietsch
Just tried it! IT WORKS!! :)
So i will just use this one as base :) I don't get why mine didn't work... but ok...
Edit:
Packing a new one works too :)
Thank you both a lot!
And another question appers :whistle:
When i put the model in, how can i choose this on the F12E?
Last edit: 23 Mar 2017 15:14 by Quietsch.
23 Mar 2017 15:19 #60623 by FDR
That RunnerAdvance.ini should be renamed to modelXX.ini in order to be able to load it.
You load a model from the model setup page selecting the "Load..." button.
23 Mar 2017 15:34 #60624 by Quietsch
Well, i thought it is a stupid idea to rename it ^^ But well that worked xD
Thanks again, now i got the basics :)
26 Mar 2017 21:00 #60783 by Quietsch
That goes more into the software but i think it is not bad placed here, otherwise feel free to move..
If i setup now a model on the F12E and try to choose the Switch in a Mixer (Simple, Complex same) the src option, and any other option to choose a switch for a channel is blinking with AUX4-7 but i can't get any proper value...
I hope you get the point, my english isn't that good...
Do you now a fix for this issue?
27 Mar 2017 03:13 - 27 Mar 2017 03:14 #60787 by M8A4X
Replied by M8A4X on topic Devo F12E Installation confusion
Did you calibrate your sticks and all your aux inputs?
The src is selected by just moving/flipping the wanted stick/knob/switch to the desired position. So if your aux inputs are not calibrated they could be "jumpy" and the src changes as they are "jumping".
Last edit: 27 Mar 2017 03:14 by M8A4X.
27 Mar 2017 04:25 #60789 by Quietsch
Ok, i calibrated all but the Gimbal knobs... Sry and thanks xD
27 Mar 2017 12:52 #60799 by Quietsch
I am able to make the model now on my F12E (all simple mixer but i get the clue) but how can i save them? I can do it by "copy to" but that isn't very comfortable :) Do you know a easy way to save them?
27 Mar 2017 13:18 #60800 by FDR
Model changes are saved whenever you switch off the TX or load an other model...
27 Mar 2017 17:44 #60815 by Quietsch
I hate those simple solutions, makes me feel stupid xD
Thank you!
Time to create page: 0.499 seconds
