devo 10 reconnect after power off - power on
- dksoft
08 Apr 2017 22:58 #61282
by dksoft
devo 10 reconnect after power off - power on was created by dksoft
Hello.
I did a test today with Walkera Furious 320g and Devo 10. During the GPS mode flight, i powered off Devo 10 to see what will happen, because i programmed my drone to Return To Home. After 5s timeout, drone initiated RTH and landed successfully. During RTH, i powered-on Devo and tried to re-gain an access to the drone, but with no luck: Walkera beeped all the time (the same behaviour when you poweroff Devo before swithing off drone.
Do anybody know if it is possible to re-establish a connection without power cycling drone?
Thank you!
Thank you!
09 Apr 2017 04:07 #61297
Replied by mwm on topic devo 10 reconnect after power off - power on
That will really depend more on the drone than the transmitter. What does it do after losing the connection? If it starts looking for a connection, then yes, you can. If you haven't set a fixed ID on the model and bound the 320g, then you might try doing so. If you haven't done that, then it would connect with anything that looks like a transmitter, and doing that midflight sounds like a bad idea to me.
- dksoft
09 Apr 2017 11:45 #61304
by dksoft
Replied by dksoft on topic devo 10 reconnect after power off - power on
Hi mwm, so basically setting a fixed ID should resolve the problem, right? Will try that.
10 Apr 2017 08:19 #61331
Well, that might fix it. I don't know that Rx and haven't tried a reconnect with any of the Walkera Rx's, but I'd be really unhappy to find out that they reconnected without being bound.
- dksoft
10 Apr 2017 19:43 #61360
by dksoft
Tested yesterday and Fixed ID works fine. The RC connects immediately after the power cycle.
Thank you!
Thank you!
Time to create page: 0.612 seconds
- devo 10 reconnect after power off - power on
