Cleanflight and betaflight see rxrange CLI command
- Deal57
12 Apr 2017 16:49 #61407
by Deal57
Cleanflight and betaflight see rxrange CLI command was created by Deal57
It seems like there are a lot of questions about various Cleanflight and betaflight configurations with Deviation. Please read
this section of the Cleanflight docs
(also applies to betaflight).
The Devo and other transmitters do not necessarily send the PWM signal endpoints exactly as used in CF/BF. In my experience with DSM receivers, Devo sends a range from 1159 to 1841, but CF and BF want 1000-2000. You can adjust Devo settings by extending the scale or (IMHO - better) through the CF or BF rxrange CLI command.
- Texacate
08 May 2017 23:06 #62180
by Texacate
Replied by Texacate on topic Cleanflight and betaflight see rxrange CLI command
Yep I ran into this too on a BeecoreF3Evo-Flysky board in CF. Had to add -4.6 of subtrim to every channel.
- Fernandez
09 May 2017 08:07 #62187
by Fernandez
Replied by Fernandez on topic Cleanflight and betaflight see rxrange CLI command
yes and deviation use % for scale. Also it depends on the protocol used.
Is there a way to read the absolute channel value as send by Tx in ms? (indeed depending on protocol selected?)
As example I had the issue in the past using model file based on Frsky D4R (PPM) and then changed the receiver to Frsky X4R (Sbus), I had to re-scale by 20%
Or only way to set up is to check the Rx range in cleanflight.
09 May 2017 08:17 #62189
Replied by FDR on topic Cleanflight and betaflight see rxrange CLI command
The TX doesn't send ms values.
They send out arbitrary digital values, which have different ranges depending on the protocol used, for example in one protocol it is a 10 bit number, in other it might be 12 bits of just 8...
Time to create page: 0.179 seconds
- Cleanflight and betaflight see rxrange CLI command
