Throttle hold for F949
- colin911
12 Apr 2017 21:55 #61409
by colin911
Throttle hold for F949 was created by colin911
Hi everyone, complete noob here. I'm building a simple model ini for my WLToys F949 plane. Using a devo 7e with 4in1. How would I add throttle hold to the hold switch?
Thanks for any guidance!
- RoGuE_StreaK
12 Apr 2017 23:09 #61410
by RoGuE_StreaK
Replied by RoGuE_StreaK on topic Throttle hold for F949
Navigate to the the throttle channel and hit Enter, change Safety from None to HOLD1, and set Safe Val to -100 (assuming throttle range is -100 to +100)
Test, preferably with prop taken off, at the least holding the plane down with hands well away from the prop and facing away from you.
For a more advanced method, search for "sticky throttle hold"; this only lets you take the throttle hold off when the throttle is fully down, so you don't accidentally activate at full throttle.
- colin911
13 Apr 2017 03:47 #61414
by colin911
Got it! Thanks so much for the help
Replied by colin911 on topic Throttle hold for F949
RoGuE_StreaK wrote: Navigate to the the throttle channel and hit Enter, change Safety from None to HOLD1, and set Safe Val to -100 (assuming throttle range is -100 to +100)
Time to create page: 0.034 seconds
- Throttle hold for F949
