Is this possible with Deviation?
- Chimera
14 Apr 2017 18:58 #61472
by Chimera
Is this possible with Deviation? was created by Chimera
Joshua Bardwell has a nice video of setting up a "safe" hold switch on his Taranis where he has to flip a switch and momentarily hold another in order to arm. Is it possible to replicate this with Deviation using a 2 position switch and one of the trims? If so can anyone point me in the right direction?
Here's the vid of what I want to do :
- SirDomsen
14 Apr 2017 19:25 #61477
by SirDomsen
Replied by SirDomsen on topic Is this possible with Deviation?
Just search for "sticky throttle hold". That's what you want. It prevents you from accidentally arm while throttle is not zero. While flying 3D, you may also setup a trim switch that zeroes throttle for a moment so that the sticky throttle hold arms.
- richardclli
25 Apr 2017 07:46 #61754
by richardclli
Replied by richardclli on topic Is this possible with Deviation?
Surely it is possible, I am using a sticky hold for almost every models. Try check out my model file attached and see how it works.
Time to create page: 0.610 seconds
- Is this possible with Deviation?
