Devo 7E Missing CC2500 error message
- lucas1414
16 Aug 2017 08:40 - 16 Aug 2017 08:46 #63815
by lucas1414
Devo 7E Missing CC2500 error message was created by lucas1414
Hello everyone!
Just finished soldering my cc2500 from banggood. And now after editing the hardware file, everytime I power on my transmitter I have the "missing Modules cc2500" error message and the transmitter won't power on.
I triple checked the soldering, shorts and mistake I could have make and I'm sure I did it like it says on the forum:
CC2500:
1-2-3-4-5-6-7-8-9-10
1 is on the pololu I ad
2 is on 3 of cyrf6936
3 is on 2 of cyrf6936
4 is on 4 of cyrf6936
5 is on 10 on the same module
6 is on gnd od pololu and gnd of the devo
7 is on 9 on the same module
8 is on TMS port of the devo
cyrf6936:
1-2-3-4-5-6-7
hpics.li/30238e0
To see if it was the pololu making a mess I have tried to connecte the cc2500 to VDD and GND, same problem.
Just so you know I instaled a walkera module for long range istead of shorting the diode...
In the Hardware.ini I just uncomment the 2 lines:
Has pa ...
enable cc2500..
Here is the module I bought: www.banggood.com/fr/CC2500-PA-LNA-Romote...95.html?rmmds=search
Maybe the module I bought from bangood is not working? do you have anything before I buy a new one?
Cheers,
Lucas.
CC2500:
cyrf6936:
1-2-3-4-5-6-7
hpics.li/30238e0
Has pa ...
enable cc2500..
Cheers,
Lucas.
Last edit: 16 Aug 2017 08:46 by lucas1414.
- lucas1414
16 Aug 2017 08:57 - 16 Aug 2017 09:33 #63816
by lucas1414
Replied by lucas1414 on topic Devo 7E Missing CC2500 error message
hpics.li/bfe0b69
Here is the hardware.ini
;enable-haptic=1
switch_types: 3x2, 3x1, 2x2
extra-switches= 3x2
;extra-buttons=
[modules]
; enable-cyrf6936 = B12
has_pa-cyrf6936 = 1
; enable-a7105 = A13
; has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
; enable-nrf24l01 = A14
; has_pa-nrf24l01 = 1
; enable-multimod = A13
;enable-haptic=1
extra-switches= 3x2
;extra-buttons=
[modules]
has_pa-cyrf6936 = 1
; has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
Last edit: 16 Aug 2017 09:33 by lucas1414.
- lucas1414
16 Aug 2017 09:50 #63818
by lucas1414
OK I double checked everything and the mistake was on the hardware file port 14 was activated instead of 13 for TMS...
Time to create page: 0.057 seconds
- Devo 7E Missing CC2500 error message
