05 Sep 2017 01:02 #64174 by Gerry
Replied by Gerry on topic New TX from Banggood
yets wrote: Anyway we could twist the manufacturers arm's to make the hall sensor gimbals compatible to Devo 7E, I'm pretty sure there'd be a lot of happy buyers... I can only dream
Agreed, hall sensor gimbals in my 7e would be fantastic.
FFS (Forever Fixing Stuff)
05 Sep 2017 01:03 #64175 by YJ
Replied by YJ on topic New TX from Banggood
Judging from the fact that these switches have three wires on each of them, and the number of diodes on board, I'd assume they are 3-way switches.
Brainstorm wrote: dc59 and All: Great to hear the manufacturer of this compact multi-protocol TX has been open to feedback from the Deviation developers!
Since I still haven't had a chance to install the 4-in-1 RF module in my Devo 7e, I pre-ordered one of these Jumper T8SG, despite the potential "public beta" risk. Based on the change from "shipping Sept. 4" to "coming soon," it sounds like BG may have delayed the initial release. So I'll be following this thread closely for any updates.
On the hall sensor question, having high-quality gimbals in a compact TX like this would be incredible! I haven't seen any information whether the switches are 2- or 3-position. But it would obviously be nice to have 3-position switches, instead of end users having to replace 2-position switches first thing.
I also agree that it would be nice to see improved ergonomics, similar to the Devo 7e. The 7e's shape and rubber grips are unequaled in a compact TX. This is perfect for travel. And the kids (with small hands) can have a TX that is on par with the grown-up versions. ;)
05 Sep 2017 01:44 #64177 by dc59
PhracturedBlue wrote: Do you want me to try to build you a firmware using their driver to get it so your screen is the right way around?
Hi PB,
T8FG maker provide source code and I upload to mediafire (13MB), it's based on Aug. 5 nightly build.
www.mediafire.com/file/r4sdzij87duli4r/deviation-0ac6094.rar
Could you please take a look at it ?
I flashed back to their FW and now my screen is OK!
05 Sep 2017 02:03 - 05 Sep 2017 05:21 #64178 by dc59
Road map of T8SG maker,
#1, improved T8SG gimbal to hall sensor and some minor changes.
#2, New model with color screen / voice support / usb charge / hall sensor gimbal .... etc.
#3, Hi-end model , all hardware design will discuss with Deviation developers,maybe will add touch screen ..... etc.
They will always listen what Deviation users need.
Edit : Their official name is Jumper and I will use this name from now.
Last edit: 05 Sep 2017 05:21 by dc59.
05 Sep 2017 04:10 - 05 Sep 2017 15:46 #64180 by vlad_vy
T8FG source code has the only difference with Aug. 5 nightly build - two lines at "target\devo7e\lcd.c".
void LCD_Contrast(unsigned contrast)
LCD_Cmd(0x81);
int c = contrast; //contrast should range from 0 to 63
LCD_Cmd(c);
void LCD_Init()
//Initialization is mostly done in SPI Flash
//Setup CS as B.0 Data/Control = C.5
rcc_peripheral_enable_clock(&RCC_APB2ENR, RCC_APB2ENR_IOPBEN);
rcc_peripheral_enable_clock(&RCC_APB2ENR, RCC_APB2ENR_IOPCEN);
gpio_set_mode(GPIOB, GPIO_MODE_OUTPUT_50_MHZ,
GPIO_CNF_OUTPUT_PUSHPULL, GPIO0);
gpio_set_mode(GPIOC, GPIO_MODE_OUTPUT_50_MHZ,
GPIO_CNF_OUTPUT_PUSHPULL, GPIO5);
LCD_Cmd(0xE2); //Reset
volatile int i = 0x8000;
while(i) i--;
LCD_Cmd(0xAE); //Display off
LCD_Cmd(0xA6); //Normal display
LCD_Cmd(0xA4); //All Points Normal
LCD_Cmd(0xEA); //??
LCD_Cmd(0xA0); //Set SEG Direction (Normal)
LCD_Cmd(0xC8); //Set COM Direction (Reversed)
LCD_Cmd(0x2C); //Power Controller:Booster ON
I will try to build devo7e-256 with these changed lines:
File deleted...
Last edit: 05 Sep 2017 15:46 by vlad_vy.
05 Sep 2017 04:24 - 05 Sep 2017 04:24 #64181 by vlad_vy
Last edit: 05 Sep 2017 04:24 by vlad_vy.
05 Sep 2017 05:13 #64183 by dc59
vlad_vy wrote: T8FG source code has the only difference with Aug. 5 nightly build - two lines at "target\devo7e\lcd.c".
Thanks vlad_vy,I will try it after work. :cheer:
05 Sep 2017 06:19 #64184 by Phobos
Replied by Phobos on topic New TX from Banggood
dc59 wrote: #1, improved T8SG gimbal to hall sensor and some minor changes.
is this #1 transmitter going to be a different product, a PRO version or something, or these are going to be the changes to T8SG production unit?
05 Sep 2017 06:24 - 05 Sep 2017 07:09 #64185 by SeByDocKy
Replied by SeByDocKy on topic New TX from Banggood
It's confirmed we can't flash it out of the box with the (modified) U7E 256 build ? with the walkera flasher ?
FYI; Jumper is one of the OEM compagnies of Banggood as Eachine can be.
Last edit: 05 Sep 2017 07:09 by SeByDocKy.
05 Sep 2017 08:49 #64188 by ajtank
Replied by ajtank on topic New TX from Banggood
It is great to have a transmitter customized for Deviation. Whilst every parent got different expectations for a new born baby, all thoughts must be realistic and justified.
$99 for Jumper's existing version seems on the high side to me when I look at the price for Devo 7e and Devo 10. Recently the legendary Frsky Taranis transmitter has also hit the $170 price point. Let's see how Jumper can emerge successfully from the market.
05 Sep 2017 10:44 - 05 Sep 2017 10:55 #64190 by mwm
Replied by mwm on topic New TX from Banggood
Fernandez wrote: hope the pcb has all cpu pins wired to jst connectors, so switches can be setup as per liking following the switches matrix and hardware.ini, maybe some extra blind holes can be premoulded in the housing with rubber stops?
If they did that - and provide easy access to some free ADC inputs - I may have to get off the pto on one of my long-term wishes: moving the hardware switch configuration into hardware.ini. Not just the extra stuff for the 7E/6S/U7E, but as much as possible.
Last edit: 05 Sep 2017 10:55 by mwm.
05 Sep 2017 12:55 #64191 by dc59
Thanks vlad_vy, it's working fine with your FW.
Does it really change only 2 line code as above?
05 Sep 2017 13:02 #64192 by dc59
#1 TX is final version of T8SG , #2 & #3 are different model and different price .............. :P
But I don't thing Banggood can sale final version of T8SG in this month because hall sensor gimbal has not been produced and tested yet.
05 Sep 2017 13:19 #64193 by vlad_vy
Yes. I compared all the source files and only one file is different. Only two lines are changed in this file.
05 Sep 2017 13:21 #64194 by yets
Replied by yets on topic New TX from Banggood
How feasible do you think it is to create hall sensor gimbals for the Devo series? The makers of the T8SG seem quite open to suggestions, and a lot of people may not be wanting to part with their Devos for this model. Surely it won't be eating into any potential sales of the new TX and also means another revenue for them while at the same time maintaining support for Deviation and also making people rethink a decision in moving over to Taranis.
If it is technically feasible could one of you developers approach them about this? Even if it's not technically achievable, how about just replacement gimbals? There is no supplier for Devo gimbals?
05 Sep 2017 13:41 - 05 Sep 2017 14:07 #64195 by vlad_vy
Once again, I will try to create separate target for T8SG.
dc59, can you test this build?
File deleted...
Last edit: 05 Sep 2017 14:07 by vlad_vy.
05 Sep 2017 13:47 #64196 by joohaky
Replied by joohaky on topic New TX from Banggood
I hope one or two switches to be added on shoulders of the final version.
05 Sep 2017 13:59 #64197 by dc59
vlad_vy wrote: Once again, I will try to create separate target for T8SG.
Something goes wrong for this build :(
05 Sep 2017 14:03 #64198 by vlad_vy
Oops, it someway use other "lcd.c", I will see into it.
05 Sep 2017 15:08 - 05 Sep 2017 15:47 #64199 by vlad_vy
Something wrong with makefiles.
make TARGET=t8sg
BUT
+ Compiling 'target/devo7e/lcd.c' wrong target!!! SRC_C = $(wildcard $(SDIR)/target/$(TARGET)/*.c)
+ Compiling 'target/common/stm32/adc.c'
+ Compiling 'target/common/stm32/clock.c'
So I need use other approach.
dc59, can you test next attempt?
File deleted...
Last edit: 05 Sep 2017 15:47 by vlad_vy.
Time to create page: 0.746 seconds
