04 Oct 2017 10:13 - 04 Oct 2017 10:14 #64797 by SirDomsen
Replied by SirDomsen on topic New TX from Banggood
Some cool things appear here!
First, I think it's quite good news to have a manufacturer that wants to support Deviation natively. The first attempt (T8SG, I have one in the mail already) might not be perfect yet, but it's a really good starting point. Looking forward for tuning parts for the Jumper T8SG as well as our beloved Devos (especially Gimbals), also made by Jumper ;)
Improvement proposal:
- better voltage suply (from what I've read) as well as 4 NiMh suport
- USB accessible from the outside
- shoulder (Kill) switch(es)
At this point, I want to say a big thank you to all people involved in Deviation, great work guys!!
Last edit: 04 Oct 2017 10:14 by SirDomsen.
04 Oct 2017 10:37 #64798 by dready
Replied by dready on topic New TX from Banggood
Hi
Is this transmitter compatible with simulators like liftoff, freerider, etc ?
And if yes what the configuration tu use for ?
04 Oct 2017 11:07 #64799 by Phobos
Replied by Phobos on topic New TX from Banggood
It should work without problem using trainer port. I'm not sure if USB HID is implemented, if it is, then connecting via USB should also work.
04 Oct 2017 12:33 - 04 Oct 2017 17:05 #64800 by vlad_vy
I've just got my Jumper T8SG.
First, it has not battery box inside, but 4 empty posts on back cover. :(
Second, it looks like rotary knobs (AUX4 and AUX5) are reversed also. In my case if knob rotated clockwise value go to -100%, counterclockwise value go to +100%. With Devo 12s if knob rotated clockwise value go to +100%. Can anybody with Devo 10 confirm common rotary knobs direction?
Third, contrast 10 (for LCD driver, not screen value) is real maximum, with higher values background will get dark.
Fourth, the green LED occasionally goes out, RF output OFF? :(
Fifth, all switches reversed, upper position = SW2, middle SW1, lower SW0. I think that it does not really matter, since they are non-typical switches.
It seems that I'm not lucky :(
Last edit: 04 Oct 2017 17:05 by vlad_vy.
04 Oct 2017 12:42 #64801 by Twilight_Sun
Replied by Twilight_Sun on topic New TX from Banggood
on devo10 rotary knobs direction is: value grows when turning clockwise. so 100% right position, -100% left position (there is a mark on knob that is on top when 0%)
04 Oct 2017 12:45 #64802 by vlad_vy
Thank you, I will reverse rotary knobs direction (AUX4 and AUX5) for T8SG build.
04 Oct 2017 15:08 - 04 Oct 2017 15:11 #64811 by kiki1
Replied by kiki1 on topic New TX from Banggood
Vlad_vy, in my t8 they are also reversed.
Last edit: 04 Oct 2017 15:11 by kiki1. Reason: edit name vlad_vy
04 Oct 2017 15:19 #64812 by vlad_vy
You can flash new firmware version T8SG with reversed AUX4 and AUX5:
www.deviationtx.com/forum/builds/7346-jumper-t8sg-builds
04 Oct 2017 17:12 #64815 by vlad_vy
vlad_vy wrote: Fifth, all switches reversed, upper position = SW2, middle SW1, lower SW0. I think that it does not really matter, since they are non-typical switches.
What do you think about switches? Is it worth fix it or leave it as is?
04 Oct 2017 17:19 #64816 by llinde
Replied by llinde on topic New TX from Banggood
For me it is better to leave switches as it is, otherwise I have to change all my models.
04 Oct 2017 18:10 #64818 by Moeder
Replied by Moeder on topic New TX from Banggood
I suggest making them consistent with the other devos, as this will make it a lot easier to have interchangeable models between different devos.
04 Oct 2017 18:22 #64819 by vlad_vy
But none of the Devo's transmitters has such switches as T8SG. When I use devo8 model for T8SG, all switches were replaced by AUX5.
04 Oct 2017 18:23 - 04 Oct 2017 18:26 #64820 by SirDomsen
+1 consistence should stay
@ llinde: You could easily change your existing model files using a text editor and just replace sw(x)0 with sw(x)2 and vice versa...
Seems somehow like one should hold the T8SG upside down to use it like a normal Devo :P :lol:
Last edit: 04 Oct 2017 18:26 by SirDomsen.
04 Oct 2017 18:37 - 04 Oct 2017 18:37 #64822 by Moeder
@vlad_vy: But most devo7e with additional switches have at least SW A and SW B, usually as a three way switch (seems to be the most common configuration).
Last edit: 04 Oct 2017 18:37 by Moeder.
04 Oct 2017 18:49 #64823 by llinde
SirDomsen wrote: +1 consistence should stay
The point about consistency I agree with, but since other Devo's have completely different names there is no consitency...
Another point is that somebody who makes models with the original firmware has to change the models when upgrading to new firmware.
Changing is not that easy as you say, you have to change sw a0 to sw ax, change sw a2 to sw a0, change sw ay to sw a2 and that for 4 switches and 45 ini files....
For me this would be a reason not to upgrade to new firmware versions.
04 Oct 2017 18:52 #64824 by llinde
vlad_vy wrote: But none of the Devo's transmitters has such switches as T8SG. When I use devo8 model for T8SG, all switches were replaced by AUX5.
And a reference to RUD DR0 in my Devo 10 profile I forgot to replace was changed to RUD on my T8SG, resulting in missing rudder control......
04 Oct 2017 18:55 #64825 by llinde
Moeder wrote: @vlad_vy: But most devo7e with additional switches have at least SW A and SW B, usually as a three way switch (seems to be the most common configuration).
This means it still is not consistent, only for a small part with some modified Devo's
04 Oct 2017 19:22 #64826 by Moeder
@llide: I meant consistent as in "switch up" is "0" and "switch down" is "1" or "2", depending on switch type. Don't underestimate the number of devo7e's (due to its price probably the most common devo) and many of them have the very easy switch mod done to them.
04 Oct 2017 19:33 - 04 Oct 2017 19:34 #64829 by llinde
Regardless the choice you make, it doesn't change the fact you have to change switchnames when transferring profiles from another Devo.
This of course is no new fact, transferring between Devo models always needs attention for switches, so reversing will not solve it, and only create two different versions of T8SG profiles, which I'm afraid will create even more confusion.
I agree that it would have been better when the manufacturer had put it the other way around.
Last edit: 04 Oct 2017 19:34 by llinde.
04 Oct 2017 20:00 #64830 by Twilight_Sun
about switches - couldn't you just mechanically turn them upside down? aren't they symmetrical?
Time to create page: 0.237 seconds
