23 Dec 2017 08:35 - 23 Dec 2017 08:41 #66583 by Wene001
Yes, you can connect PPMout on the T8SG to the Multipro module.
i would go another way....
i would buy www.tmart.com/BoldClash-BWhoop-B03-Pro-0...r-Board_p368452.html
or www.banggood.com/Eachine-E011-RC-Quadcop...rch&cur_warehouse=CN
and use the Bayang protocol.
Another advantage is, that you can flash these boards with silverware, so you can fly in acromode and use telemetry for low battery alarm.
sirdomsen.diskstation.me/dokuwiki/doku.php
Last edit: 23 Dec 2017 08:41 by Wene001.
23 Dec 2017 09:34 #66584 by goebish
+1, the nrf24-multipro is not really meant to be used with a Devo, better use another FC.
23 Dec 2017 19:02 - 23 Dec 2017 19:02 #66586 by SirDomsen
kabuto wrote: Hello! My T8SG cannot bind with E010, is it possible to use the nrf24 multipro module to made it work?
As far as I know, every protocol supported by the multipro is supported,by Deviation e.g. T8SG also. So nothing will,change. I think E010 Protocol is,a sub protocol of MJXq, selected by pressing 'ent' while at protocol,selection page - IIrc (I don't fly E010 either, I also prefer Silverfied quads :D )
Last edit: 23 Dec 2017 19:02 by SirDomsen.
23 Dec 2017 19:12 #66587 by goebish
The E010 is known to have issues, especially with x-in-1 modules, probably because of frequency drift, there's nothing we can do in software.
www.deviationtx.com/forum/protocol-devel...otocol-bind-problems .
23 Dec 2017 19:25 #66589 by FDR
I think we should mention it on the supported model list, because this question rises quite often...
24 Dec 2017 02:10 #66592 by kabuto
Thanks for the reply, already ordered E011 from banggood, meanwhile I try to connect nrf24-multipro to T8SG but no success!
Connect nrf24-multipro through trainer port, choose PPM protocol, then follow the instruction but not working!
Is there something else I need to do?
24 Dec 2017 02:12 - 24 Dec 2017 02:28 #66593 by goebish
Do you have a DIY or "genuine" nrf24-multipro ?
Most of the cheap ones on banggood don't work with the E010 either.
If using my firmware from github, expected channel order is TAER (deviation is AETR by default), and you'll probably have to reverse rudder & aileron to use it with deviation.
Modules using this board usually work with the E010 (that's what I use to make the nrf24-multipro modules):
www.banggood.com/DEVO-Transmitter-Tuner-...ys-V922-p-89812.html
Also works perfectly when installed into a Devo.
Last edit: 24 Dec 2017 02:28 by goebish.
24 Dec 2017 02:29 #66595 by kabuto
The link you posted is the one I put in my 7E, works perfect with E010.
What I had tried are cheap ones on banggood, both of them are not working, the led never lit up!
24 Dec 2017 02:35 - 24 Dec 2017 02:36 #66596 by goebish
Ok, most of those modules are having issues with the E010 (latency, short range, or doesn't bind at all), sorry but you're screwed ;)
Last edit: 24 Dec 2017 02:36 by goebish.
24 Dec 2017 02:38 #66597 by kabuto
OK! Thanks for the info.
04 Jan 2018 18:03 #66713 by yets
Any news on the gimbals?
04 Jan 2018 19:55 #66714 by dready
yets wrote: Any news on the gimbals?
www.helicomicro.com/2018/01/02/jumper-t8sg-plus-en-approche/
Jumper T8SG Plus, approaching :
The T8SG multiprotocol radio control from Jumper will be available soon in a new and updated version. What will change? It will be possible to change the transmitter module, the joysticks are Hall effect models, the screen will be OLED, and there will be 4 new switches! Hopefully, the USB connector is more accessible than the original version. There is still no date or price for the T8SG Plus ...
05 Jan 2018 11:39 #66722 by Brainstorm
Replied by Brainstorm on topic Jumper T8SG - First TX stock - power options
ramunas wrote: I have experimented replacing the original hi-dropout voltage 3.3v and 5v linear regulators with Pololu up/down 3.3v and up 5v switching regulators on 4xAA Eneloops or 1x18650 Li-Ion battery.
So I reduced the 560K between A3 and J1 switch pin1 to 240K, and the shutdown save now works fine down to 2.8v. With that it seems possible to have a single 48gram Li-Ion cell provide 3000+mah. The reduced weight is nice. Note that 4 Eneloops in a Walkera battery holder are around 125grams.
Nice experiment, Ramunas! Since the T8SG won't accept 4xAA, I would love to just install a 18650 cell and call it a day. It would be even cooler if the updated T8SG Plus could come with an 18650 standard from the factory!
05 Jan 2018 17:12 - 05 Jan 2018 17:12 #66730 by yets
Good news for jumper owners, what about us lowly Devo users?
Last edit: 05 Jan 2018 17:12 by yets.
05 Jan 2018 17:23 #66731 by Iroquois
Don't tell me - it's left foot will crack walnuts. Oh yes, the case will be twice as big.
07 Jan 2018 10:00 #66750 by MikefromGermany
Replied by MikefromGermany on topic Jumper T8SG - First TX stock running on Deviation
You still will have a far superior TX.
17 Jan 2018 08:02 #66923 by glenby
sorry if this is in wrong place but searching kept bringing me back here.
T8SG - stock firmware.
cannot save changes except model name.
rebooting wipes everything. changing models wipes changes.
flashed firmware from nightly build - deviation-t8sg-v5.0.0-e292f38.dfu
same issue.
any ideas on how to actually save?
the manual doesnt say. Long press on ENT doesnt do it.
if this is wrong area, let me know and I'll post elsewhere.
thanks and apologies for something that seems very simple.
a few disparate kites
17 Jan 2018 08:22 #66924 by Iroquois
It's fairly obvious but you may have missed it:
In the 'Mixer' menu you have to save each stage by selecting the 'Save' flag and then pressing 'Enter'. Everything else should save automatically.
17 Jan 2018 10:05 #66925 by glenby
Iroquois wrote: It's fairly obvious but you may have missed it:
thanks. I have been doing that but no luck.
even saving in mixer (add extra channels, save but things dont save).
I want to use frsky protocol. cannot save it.
If I go to the model menu to load, it shows the current model as not saved.....
sigh.
17 Jan 2018 11:10 #66926 by vlad_vy
If you use fully charged 2S Lipo, you need replace faulty transmitter. It will be second known case with T8SG that can't save settings.
Time to create page: 0.287 seconds
