30 Apr 2018 07:30 #68933
Replied by vlad_vy on topic Jumper T8SG - First TX stock running on Deviation
Front long handle switch will interfere with gimbal handle.
- Iroquois
30 Apr 2018 11:23 #68935
by Iroquois
Replied by Iroquois on topic Jumper T8SG - First TX stock running on Deviation
Not on mine it doesn't.
- zarni
30 Apr 2018 12:47 - 30 Apr 2018 12:48 #68937
by zarni
Replied by zarni on topic Jumper T8SG - First TX stock running on Deviation
I put long handle switches on SWB & SWC. My fingers hit if I pinch the sticks.
Maybe it depends on hand size and pinch style?
I'm a "thumber" though, and the long handles make it a lot easier to flip those inner switches while keeping the thumbs on the sticks.
vlad_vy wrote: Front long handle switch will interfere with gimbal handle.
Iroquois wrote: Not on mine it doesn't.
Last edit: 30 Apr 2018 12:48 by zarni.
- xalex75
25 May 2018 12:39 - 25 May 2018 12:53 #69402
by xalex75
Can this be related to the interference I'm having in FPV after binding tx and receiver (different whoops, different cameras, different channels, same problem)?
Replied by xalex75 on topic Jumper T8SG - First TX stock running on Deviation
vlad_vy wrote: Warning!!!
With "Jumper T8SG V2 Plus" there is RF noise to Hall sensor wires problem. It depends from used protocol and output power. The simple solution is to unplug wires, twist the wires to protect them from electromagnetic interference and plug them back in.
Last edit: 25 May 2018 12:53 by xalex75.
- LiNuS_
17 Aug 2018 14:46 #70305
by LiNuS_
Replied by LiNuS_ on topic Jumper T8SG - First TX stock running on Deviation
Hello people of deviation.
Im almost on the way to get a jumper radio but i dont know wich One to choose.
I read a lot about the Plus hall gimbals and OLED screen that is not very good in direct sun light.
About the gimbals, i cant find anything showing that the V2 are indeed diferent from the v2 Plus, but at the product description both says "Rocker way: non-contact 3D space vector Hall joystick".
Basically i dont know wich one to choose in between Hall gymbals over good LCD viewing in direct sun light.
About the firmware, its the same and compatible one the V2 fw and V2 Plus fw?
Hope someone can guide me and help me to decide for the best.
Thank you and sorry my english
- goebish
- NRF Weirdo
17 Aug 2018 17:28 #70308
by goebish
Replied by goebish on topic Jumper T8SG - First TX stock running on Deviation
Favor better gimbals, you won't be looking at your screen that often while flying
- Iroquois
18 Aug 2018 03:10 #70315
by Iroquois
This may help:
www.iroquois.free-online.co.uk/multi.htm
- Bug
24 Sep 2019 16:42 #75148
by Bug
Replied by Bug on topic Jumper T8SG - First TX stock running on Deviation
Has anyone hacked a module bay mod on the t8sg v1 ?
There are several printed module bays on banggood and co for the lite transmitters and it seems not to be that much of a problem to solder these loose wires to the pcb, but I don't really know where to start and it would be reassuring if someone already had done it before.
It would be nice to have the t8sg as a spare for a r9m module.
- Iroquois
24 Sep 2019 21:01 #75149
by Iroquois
What would the module do that the T8SG doesn't do anyway?
- IanHarlow
09 Oct 2019 13:09 - 09 Oct 2019 13:12 #75210
by IanHarlow
Replied by IanHarlow on topic Jumper T8SG - First TX stock running on Deviation
Last edit: 09 Oct 2019 13:12 by IanHarlow. Reason: To include the OP username
19 Oct 2019 00:58 #75286
Replied by hexfet on topic Jumper T8SG - First TX stock running on Deviation
Yes, it's for PPM in and out. When PPM is selected as the protocol it's the output pin for PPM. For other protocols that are not serial protocols, it can be used as PPM In for things like master trainer.
Other serial protocols also use this pin for output - PXX, CRSF, SBUS, SUMD. Can't use these with PPM In.
28 Feb 2020 04:44 #75972
I got my JumperTX T8SG, it's completely same as Jumper T8SG V2 Plus with black body, LCD screen and USB Type C. It can use Deviation t8sg_v2 firmware.
www.banggood.com/JumperTX-T8SG-2_4G-12CH...482&cur_warehouse=CN
28 Feb 2020 05:00 - 28 Feb 2020 05:04 #75973
Some interesting things:
* with factory firmware "errors.txt" file has error record,
* after flashing custom firmware based on v5.0.0 release, filesystem completely disappeared and USB drive can't be read, I need format transmitter USB drive and write v5.0.0 filesystem.
www.deviationtx.com/forum/builds/6407-de...cols?start=500#75331
Last edit: 28 Feb 2020 05:04 by vlad_vy.
- YJ
28 Feb 2020 05:10 #75974
by YJ
Interesting transmitter and thanks for sharing.
Did you mean t8sg_v2 or t8sg_v2_plus firmware? If v2, are there any features missing from this transmitter compared to jumper's v2 plus?
Replied by YJ on topic Jumper T8SG - First TX stock running on Deviation
vlad_vy wrote: I got my JumperTX T8SG, it's completely same as Jumper T8SG V2 Plus with black body, LCD screen and USB Type C. It can use Deviation t8sg_v2 firmware.
28 Feb 2020 05:19 #75975
It use "t8sg_v2" firmware. Both "t8sg_v2" firmware and "t8sg_v2_plus" firmware have the only difference - LCD or OLED driver.
- Fernandez
29 Feb 2020 19:56 #75978
by Fernandez
Replied by Fernandez on topic Jumper T8SG - First TX stock running on Deviation
Hi Vladimir, in the current builds the power button needs to be pressed 3seconds to power off. Great !!!
But is it possible also to power on by pressing 3seconds, so it cannot accidentally switched on and drain batteries? And could we have a beep, at power down when we can loose the button?
(and I always hate/annoys me in this transmitter the enter button to be the big left button, the back button the top left, or is it just me who always accidentally press wong button? )
- eried
01 Mar 2020 19:59 #75979
by eried
Replied by eried on topic Jumper T8SG - First TX stock running on Deviation
Strange that it says "voice support" in banggood but it does not seem to have voice support really...
04 Mar 2020 08:54 #75992
Tested delayed "Power On", but I'm not sure I like it. I personally prefer fast "Power On".
About power down beep, do you try to use "PwrDn alert" at Transmitter config?
- eried
04 Mar 2020 09:40 #75993
by eried
I also prefer instant on. It has never happened to me that it turn on inside of the case.
- Fernandez
04 Mar 2020 12:51 #75996
by Fernandez
Ah good one, "PwrDn alert", will look into that, not tried that.
For power on and off, at least al transmitters I am aware, with a "software" on/off switch, there is a protection mechanism. Either pushing two buttons, either having a long press etc.
But yes open for discussion, protect for switch accidentally off, indeed is most important and is covered now.
Time to create page: 0.265 seconds
- Jumper T8SG - First TX stock running on Deviation
