Jumper T8sg and E010s flysky AFHDS = latency
- goebish
- NRF Weirdo
12 Oct 2017 20:52 - 13 Oct 2017 00:15 #65003
by goebish
Replied by goebish on topic Jumper T8sg and E010s flysky AFSDH = latency
I replaced the 4-in-1 module, and it's working perfectly now ...
I don't think we can do anything in firmware, I'll tell dc59 to have a look at this thread and explain Jumper what's happening.
I think the problem is that the 4-in-1 module is not using a+/-20ppm +/-10ppm accuracy crystal for the A7105.
Stock module removed (I hate lead free solder, that required 400°C hot air) :
Stock module :
New module installed (it has 1 less pin, nrf24l01 CE, but this has no importance ...) :
edit: according to the datasheet, a +/-10ppm crystal is required when the Rx does not use frequency compensation, which is probably the case of flysky Rx clones.
Stock module :
Last edit: 13 Oct 2017 00:15 by goebish.
- goebish
- NRF Weirdo
12 Oct 2017 21:25 #65005
by goebish
- fredbotton
12 Oct 2017 21:42 #65006
by fredbotton
Replied by fredbotton on topic Jumper T8sg and E010s flysky AFSDH = latency
Ok, so first batch A7105 is faulty, but next one with moved microUSB is ok, right?
- goebish
- NRF Weirdo
12 Oct 2017 21:45 - 12 Oct 2017 21:57 #65007
by goebish
No idea, that's too soon to draw a conclusion, I rather think they're still using the same module, therefore that's just luck.
Last edit: 12 Oct 2017 21:57 by goebish.
- Bug
13 Oct 2017 12:10 #65026
by Bug
Replied by Bug on topic Jumper T8sg and E010s flysky AFSDH = latency
my T8SG arrived yesterday an I got a version with hidden usb.
So from this thread I concluded it's an"old" version, but they seem to still deliver them, I had to wait some time for it, it's the latest from China.
Are there any clues, that can differentiate a newer version ?
I've bound it with an eachine racer 130 with an old AFHDS receiver and I don't see any lag.
13 Oct 2017 13:01 #65032
Replied by vlad_vy on topic Jumper T8sg and E010s flysky AFSDH = latency
USB position, all other is same.
- goebish
- NRF Weirdo
13 Oct 2017 13:07 - 13 Oct 2017 13:08 #65033
by goebish
I think that's just a matter of (bad) luck for now, if you can bind to and control all your aircrafts you shouldn't be concerned
Last edit: 13 Oct 2017 13:08 by goebish.
- goebish
- NRF Weirdo
13 Oct 2017 13:12 - 15 Oct 2017 22:32 #65035
by goebish
And maybe (probably) the Rx in the E010S is at fault too, let's say its firmware does not use frequency compensation (that's probably the case...) and it also has an inaccurate crystal oscillator that drifts in the opposite direction ...
edit: confirmed, this can happen even with genuine flysky / turnigy AFHDS transmitters:
www.rcgroups.com/forums/showthread.php?2...mode%29#post36430221
Last edit: 15 Oct 2017 22:32 by goebish.
- Bug
13 Oct 2017 18:47 #65042
by Bug
Replied by Bug on topic Jumper T8sg and E010s flysky AFHDS = latency
I've spent the afternoon binding and flying a lot of my stuff. I don't see any issues with the old AFHDS (1) receiver nor with two other eachine AFHDS 2 receivers.
I hoped to find a production date somewhere, but the only hint is the 0ac6094 firmware which maybe arrived in May and is the same on all current models.
My mainboard looks exactly the same as yours on the photos which is strange, because banggood is posting them as soon as they get them. The usually don't have dated stock.
There are no hints on the rf module to see if it's another batch.
Thank you for your infos, they helped a lot.
- goebish
- NRF Weirdo
13 Oct 2017 20:27 - 15 Oct 2017 22:10 #65045
by goebish
Replied by goebish on topic Jumper T8sg and E010s flysky AFHDS = latency
Good news AlbE & Fred, I think I was right when I was pointing out the frequency drift (110 kHz) of the "bad" module was the culprit:
I found a way to fine tune the A7105 Tx frequency (registers 0x11, 0x12 & 0x13: LO base frequency), I was able to set it to the same drift than thedefective other module and reproduced the issue !
Now let me code something that's more user friendly to fine tune the frequency (as with cc2500 protocols) then it might fix your problem !
Last edit: 15 Oct 2017 22:10 by goebish.
- Bug
13 Oct 2017 21:17 #65047
by Bug
Hero. That's great. Thank you.
- goebish
- NRF Weirdo
13 Oct 2017 23:10 - 14 Oct 2017 12:57 #65048
by goebish
Here's a test build with a new Flysky protocol option: Freq Tune
Use it to adjust the A7105 LO base frequency, it can be fine tuned from -200 to +200 kHz, that should be enough ...
The best setting has to be found manually, as this is a 1 way protocol there's no way to auto-tune.
Firmware for T8SG, you only have to flash the .dfu with devention DfuSe Upgrade Tool:
www.dropbox.com/sh/mw7ltu27dvr69o2/AACLP...FaAaUqXRqNWSzHa?dl=0
And as a bonus, a video for AlbE & Fred that explains how to fine tune, in french
Please report !
Please report !
Last edit: 14 Oct 2017 12:57 by goebish.
- AlbE
14 Oct 2017 08:25 #65051
by AlbE
Replied by AlbE on topic Jumper T8sg and E010s flysky AFHDS = latency
Thanks Goebish for all your work and research
Do you have a link in order to have some explanation about DfuSe Upgrade Tool ? I never use it
- goebish
- NRF Weirdo
14 Oct 2017 10:43 #65053
by goebish
You can take a look at SeByDocKy's tutorial:
- goebish
- NRF Weirdo
14 Oct 2017 15:42 - 14 Oct 2017 15:44 #65055
by goebish
Note that if you still were on factory firmware you'll have to (un)reverse aileron & rudder channels for all your existing models after updating.
Last edit: 14 Oct 2017 15:44 by goebish.
- goebish
- NRF Weirdo
14 Oct 2017 16:12 - 14 Oct 2017 16:20 #65057
by goebish
Last edit: 14 Oct 2017 16:20 by goebish.
- Elric
14 Oct 2017 17:16 #65058
by Elric
Replied by Elric on topic Jumper T8sg and E010s flysky AFHDS = latency
Salut, ton option sera-t-elle présente pour les Walkera Devo xx ?
Hi, will your option be present for the Walkera Devo xx?
- goebish
- NRF Weirdo
14 Oct 2017 17:18 #65059
by goebish
If AlbE & Fred confirm that it fixes the problem, yes.
- Gerald
14 Oct 2017 18:50 #65061
by Gerald
Replied by Gerald on topic Jumper T8sg and E010s flysky AFHDS = latency
Bonjour Goebish, j'ai essayé ton dernier firmware, ça arrange les choses mais il y a toujours une petite latence (je suis à -186) et de plus avec ce firmware je ne peux plus utiliser les interrupteurs. J'ai d’ailleurs récupéré mon ancien fichier de modèle pour le E010S mais il ne fonctionne plus après la mise a jour du firmware, j'ai du repartir d'un vide. Merci.
Hello Goebish, I tried your last firmware, it arranges things but there is always a small latency (I am at -186) and more with this firmware I can no longer use the switches. I also recovered my old model file for the E010S but it no longer works after the firmware update, I had to start again from a vacuum. Thank you.
- goebish
- NRF Weirdo
14 Oct 2017 18:57 - 14 Oct 2017 19:04 #65062
by goebish
Do you feel you'd need more range ?
I can do it though I think that +/-200 kHz is already a lot. I mean that if you really need a 200 kHz drift then it wouldn't bind at all without tuning in the first place ...
Regarding switches, I don't know, they're working fine on my end, I used vlad's source code for T8SG, maybe they have been renamed compared to the factory firmware.
Last edit: 14 Oct 2017 19:04 by goebish.
Time to create page: 0.604 seconds
- Jumper T8sg and E010s flysky AFHDS = latency
