Flysky Pro micro AFHDS ppm receiver with Devo 7e
- Aron76
27 Oct 2017 16:33 #65310
by Aron76
Flysky Pro micro AFHDS ppm receiver with Devo 7e was created by Aron76
I am building a brushless tiny whoop and I chose a flysky AFHDS ppm receiver for it. The idea was to bind it with my Devo 7e and live forever. Now I am stuck as the receiver seems to bind but still there is no reaction in Betaflight to stick movement from my Devo. The receiver is set to ppm and the led light is solid still doesn't work.
Any idea? What am I doing wrong? What kind of protocol should I set on my Devo for this receiver at all? I have set Flysky with the Wltoys set to off.
Please help me!
Please help me!
- Deal57
28 Oct 2017 14:35 #65327
by Deal57
Replied by Deal57 on topic Flysky Pro micro AFHDS ppm receiver with Devo 7e
Can you confirm that you have the A7105 or 4-in-1 module? If the protocol has an asterisk ("*") then Devo doesn't see the transmitter board. Which flight controller board are you using? Can you provide a link to the receiver? I've used a couple of the cheap little AFHDS receivers and the ones that work are fine. But they can be sensitive to voltages or FC quirks.
Time to create page: 0.064 seconds
- Flysky Pro micro AFHDS ppm receiver with Devo 7e
