E010 latency with T8SG
04 Nov 2017 18:22 - 04 Nov 2017 21:55 #65512 by Naudnaud
E010 latency with T8SG was created by Naudnaud
Hello !!
I have for some day a radio control T8SG.
Who serves me has to pilot my small quad:
E010 (Green)
H107D
FQ777-124
For the moment everything works fine.
Except that today I am to buy the second E010 (red) to go up it in fpv with a TX01.
And this E010 ( red) I wants not to work, or works very badly with my T8SG.
When I arrive in him bind, the Quad in a lot of latency. Command put between 0.5sec and 2sec to be taken into the quad.
Have you an idea where from can come the problem? Thank you!
Last edit: 04 Nov 2017 21:55 by Naudnaud.
05 Nov 2017 01:01 - 05 Nov 2017 01:02 #65526 by goebish
Replied by goebish on topic E010 latency with T8SG
This is a known issue with the E010, depending of the accuracy of the crystal oscillators in the Tx and Rx, unfortunately there's nothing we can do in software.
www.deviationtx.com/forum/6-general-disc...iprotocol-t8sg#65223
edit: try to lower Tx power to 30mW, that might be better.
Last edit: 05 Nov 2017 01:02 by goebish.
05 Nov 2017 07:54 #65534 by Naudnaud
Replied by Naudnaud on topic E010 latency with T8SG
Ok, but my first E010, the green one work perfectly.
I'm always in 30mW for indoor. (same problem in lower power)
this is accuracy of the crystal oscillators in the Tx and Rx too ?
05 Nov 2017 10:08 #65539 by goebish
Yes, that's just a matter of luck, maybe if you get a 3rd one it will work perfectly ... or not at all.
10 Nov 2017 21:44 #65718 by Naudnaud
I received my 3rd E010 ( a red one)
Impossible to bind -_-
Possible to have fine tuning for E010 ?
10 Nov 2017 21:45 #65719 by goebish
No, that's not possible with the nrf24l01. (unlike the 3 other chips ...)
10 Nov 2017 21:58 #65720 by goebish
My advice: forget about the e010 and get an e011 or bwhoop b-03 pro instead, they're the same size, more powerful (0715 motors) and are using the Bayang protocol which is working perfectly as it's 1 Mbps.
11 Nov 2017 12:31 #65749 by Naudnaud
Ok, i buy a E011.
It's the updated version of the E010 ?
11 Nov 2017 16:45 #65755 by goebish
More or less.... it's the same frame with more powerful motors.
Time to create page: 0.109 seconds
