The next clone just round the corner.;-)
14 Nov 2017 23:03 #65835 by aMax
14 Nov 2017 23:28 - 19 Nov 2017 21:27 #65836 by Fallingwater
Replied by Fallingwater on topic The next clone just round the corner.;-)
Came here specifically to post this.
It seems to have a four-chip multimodule setup similar to the Devo/Jumper, but there's no mention in the description of DeviationTX and they say it has 255 model memories, which makes me think they're running their own software. I like this thing's design, I like the price and I like that I don't have to pay for the genuine article's supertiny FPV screen that I'm overwhelmingly likely never to use - but I don't trust undocumented proprietary software with my quads' lives.
I'll be watching the reviews, and hopefully DeviationTX can be ported to it. If we get this Deviated I know what transmitter I'll be carrying in my FPV backpack for casual flights.
Last edit: 19 Nov 2017 21:27 by Fallingwater.
15 Nov 2017 03:44 - 15 Nov 2017 03:52 #65838 by vlad_vy
Replied by vlad_vy on topic The next clone just round the corner.;-)
I'm in doubt it use Deviation, but I don't see any difference with Deviation devo7e-256 capabilities: 128x64 LCD, 6 buttons, 4 trims, 6 switches, 2 rotary knobs, USB drive, localized, virtual channels, 255 models and so on.
I don't like how rotary knobs positioned, they easily can be accidentally rotated with shoulder switch switching. And, it quite large, even bigger than Devo 8s.
Last edit: 15 Nov 2017 03:52 by vlad_vy.
15 Nov 2017 07:21 #65843 by FDR
Well, with this button layout the navigation will be a nightmare for sure... :)
15 Nov 2017 07:29 #65845 by SeByDocKy
Replied by SeByDocKy on topic The next clone just round the corner.;-)
10 samples will be available from 11-30..... @BG mainly for reviewers I guess
15 Nov 2017 08:20 #65846 by dc59
Replied by dc59 on topic The next clone just round the corner.;-)
TBS Tango case + DeviationTX ??
15 Nov 2017 12:53 #65849 by Iroquois
Replied by Iroquois on topic The next clone just round the corner.;-)
iRangeX uses Open TX. Surely someone noticed that.
15 Nov 2017 14:27 #65850 by FDR
Can you share, where does this info come from?
All the text (like for example the virtual channels) suggest usage of deviation, but the only drawing about the fw (probably the main page) is not alike...
15 Nov 2017 14:39 #65851 by Moeder
Replied by Moeder on topic The next clone just round the corner.;-)
Even more than that, the description of features is a 95 % copy of the deviation homepage
15 Nov 2017 15:19 - 15 Nov 2017 15:21 #65853 by aMax
Replied by aMax on topic The next clone just round the corner.;-)
Fallingwater wrote: Came here specifically to post this.
.....cut
Edit: already out of stock!
But they start with 30 models... ;) what a surprise..
You can even have this amount of models on your devo, but I am too lazy to prebuild such an amount of files, so I end up with 60.
Last edit: 15 Nov 2017 15:21 by aMax.
15 Nov 2017 18:43 #65858 by hexfet
Replied by hexfet on topic The next clone just round the corner.;-)
Iroquois wrote: iRangeX uses Open TX. Surely someone noticed that.
If you're referring to the IRangeX multimodule, that's just a commercialized DIY-Multimodule. That project has added a serial interface and with OpenTX the protocol can be selected. So it's possible they could be using the multimodule inside with OpenTX. But the description sure sounds like Deviation.
Haven't looked into the details but I think the serial interface might be based on PXX from what I've seen in forum posts. Not sure if the link is in OpenTX code or a lua script. Maybe telemetry to OpenTX is supported too.
15 Nov 2017 22:20 #65868 by Fernandez
Replied by Fernandez on topic The next clone just round the corner.;-)
Or it is based on a devo 6e?
anyway I like this one from the looks more than jumper, a pity that again this stuff is released by a surprice and seem Voice is lacking?
17 Nov 2017 17:31 #65947 by SeByDocKy
According to BG, it's DeviationTX based :) (maybe the 255 config files supported is false)
17 Nov 2017 22:38 #65954 by aMax
...but the desciption says >" model memory: 30."
How many models are supported on Deviation? I am quite sure 254 are possible,...if someone does the job ;-).
Hence no difference.
17 Nov 2017 23:53 #65956 by FDR
AFAIK deviation had a theoretical limit of model files at 255, but that includes the template files as well, so it is actually less then 255.
If I remember well we limited it to 200.
There is only 30 ini files by default, but you can make more, just be sure the numbering is continuous...
18 Nov 2017 07:10 - 18 Nov 2017 07:11 #65967 by vlad_vy
Model limit is exactly 255 for Nightly Builds (200 for v5.0.0).
int model_count()
    int num_models;
    for (num_models = 1; num_models <= 255; num_models++) {
        sprintf(tempstring, "models/model%d.ini", num_models);
        FILE *fh = fopen(tempstring, "r");
        if (! fh)
            break;
        fclose(fh);
        CLOCK_ResetWatchdog();
    num_models--;
    return num_models;
Last edit: 18 Nov 2017 07:11 by vlad_vy.
Time to create page: 0.789 seconds
