Jumper T8SG | Binding versus Re-Init
- Brett_N
22 Dec 2017 23:53 #66580
by Brett_N
Jumper T8SG | Binding versus Re-Init was created by Brett_N
So, now that a few more of the production versions of the Jumper radio are out.....
Can someone explain the difference between "Bind" and "Re-Init" in the model sub-menu for the TX protocol? I was searching for the protocol for my Volantex plane, and about 2/3rds of the protocols use re-Init rather than bind, which makes me think it's turned off.
E-Flite DMSX works fine.
Syma Protocol works fine.
WL Toys Protocol works fine
Eachine, no dice. Just says re-init in the menu, no option for Bind.
Do we need to "turn on" some additional radio function somewhere in Deviation?
Sorry if this sounds dumb....
23 Dec 2017 08:28 #66582
Replied by FDR on topic Jumper T8SG | Binding versus Re-Init
Many protocols don't support binding, but simply auto bind at startup.
With re-init you can repeat that auto bind procedure as if you just turned on the TX.
- Brett_N
23 Dec 2017 17:25 #66585
by Brett_N
Replied by Brett_N on topic Jumper T8SG | Binding versus Re-Init
Makes sense - thank you sir!
Time to create page: 0.488 seconds
- Jumper T8SG | Binding versus Re-Init
