- Fernandez
08 Jan 2018 21:59 - 08 Jan 2018 22:00 #66770
by Fernandez
iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol was created by Fernandez
I thought this new radio needs it's own topic to post feedback
To introduce;
This is after Jumper, the second Open source radio released which is particularly designed for running with DeviationTX firmware and not related to any HF protocol or receiver itself.
Money will be made just on the TX hardware.
A big difference with Frsky openTX Radio, were the Frsky RF link itself is not open standard, neither it supports multiple RF protocols without inserting addional modules.
I hope that this transmitter hardware becomes a great succes, with more than 850 units on preorder, I expect reviews to get in soon after release.
I hope that this one adresses;
-Quality Hall Gimbals
-USB Chargeable liion
-Voice Module
-Nice in hand feel
To introduce;
-Voice Module
-Nice in hand feel
Last edit: 08 Jan 2018 22:00 by Fernandez.
- betoinbeta
16 Jan 2018 22:34 #66915
by betoinbeta
Replied by betoinbeta on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
Not sure if any other person who pre-ordered this multi-protocol TX received this message from BangGood (1/16/2018).
"We’re sorry to inform you that the preorder for the item [iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol Transmitter With PPM S.BUS Mini Receiver] was delayed due to a delay in the manufacturing process."
There's no real ETA given.
I too an excited to see this thing out in the wild.
- Piedro
19 Jan 2018 01:24 #66971
by Piedro
Replied by Piedro on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
- Mitchie
19 Jan 2018 03:02 #66977
by Mitchie
Replied by Mitchie on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
Got mine today! I haven't bound it to anything yet but so far it's looking pretty good! It feels nice in the hands and it's light.
19 Jan 2018 05:01 #66980
Replied by FDR on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
Can you check on the about page what fw version does it use?
19 Jan 2018 13:30 - 19 Jan 2018 13:33 #66996
Replied by vlad_vy on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
Surprise!!!
iRangeX iRX-IR8M has Jumper T8SG firmware (t8sg-v5.x.x-2017-09-19).
Last edit: 19 Jan 2018 13:33 by vlad_vy.
20 Jan 2018 08:48 - 20 Jan 2018 08:55 #67009
It looks like iRX-IR8M has four 3-pos switches and two shoulder 2-pos switches:
I need confirmation from Mitchie.
As usual things messed: all switches reversed, AUX4 and AUX5 reversed, stick directions the same as for devo7e-256, batt_critical need to be 3900, since iRX-IR8M can work with 4xAA battery.
Last edit: 20 Jan 2018 08:55 by vlad_vy.
- antennenfreund
20 Jan 2018 16:48 - 20 Jan 2018 16:56 #67016
by antennenfreund
Replied by antennenfreund on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
Hello, I'm new here!
Unfortunately, I speak very poor English and use Googel for help.
I also ordered this transmitter. I would like to use my Futaba FASST receiver. Unfortunately, I do not quite understand if it is supported. Do I have to order new receivers?
If it is not supported, can you tell me which recipient to buy? He should have full range. I'm flying with FPV Racer.
Unfortunately, my English is too poor to understand if my recipient is supported.
How much mw does the sender have? (Transmission power in mw max)????
Last edit: 20 Jan 2018 16:56 by antennenfreund.
- Ariete
20 Jan 2018 19:03 #67019
by Ariete
Replied by Ariete on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
Futaba FASST is not supported by deviation you can use any receiver with a supported protocol:
Supported protocols
Supported protocols
- antennenfreund
20 Jan 2018 20:17 #67024
by antennenfreund
Will this recipient function or?
FrSky R-XSR Ultra Mini ?
- Fernandez
20 Jan 2018 23:18 #67025
by Fernandez
Replied by Fernandez on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
Yes that works well and it is the lightest full range diversity telemetry receiver out there !
22 Jan 2018 06:26 - 22 Jan 2018 06:28 #67035
OK, now I know the switch config: 3x4 (A, B, C, D) + 2x2 (G, H)
;switch_types: 3x4, 3x3, 3x2, 3x1, 2x8, 2x7, 2x6, 2x5, 2x4, 2x3, 2x2, 2x1, potx2, potx1
;Add nostock if stock FMOD and HOLD switches have been removed.
extra-switches = nostock
extra-switches = 3x4
extra-switches = 2x2
extra-switches = potx2
Last edit: 22 Jan 2018 06:28 by vlad_vy.
22 Jan 2018 14:11 #67045
I suspect that iRangeX use "hardware.ini" from T8SG without modification, so "H" and "G" shoulder switches are undefined.
23 Jan 2018 04:25 - 23 Jan 2018 04:25 #67058
Confirmed. Stock iRangeX iRX-IR8M "hardware.ini" file is:
;enable-haptic=1
; extra-switches = 2x2
;Audio player connected to UART (Devo12/S internally, others via trainer port): audiofx, dfplayer
;voice=
;Enable if audio device is wired to uart5 instead of ppm on devo7e-256
;voice-uart5=1
;extra-buttons=
[modules]
; enable-cyrf6936 = B12
; has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
enable-nrf24l01 = A15
has_pa-nrf24l01 = 1
; enable-multimod = A13
Last edit: 23 Jan 2018 04:25 by vlad_vy.
23 Jan 2018 05:40 #67059
Changing "hardware.ini" doesn't help enable shoulder switches. From mainboard images it looks like they connected to AUX4 and AUX5 pots. I don't know why they needed.
- SeByDocKy
23 Jan 2018 14:32 #67072
by SeByDocKy
Replied by SeByDocKy on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
I just received mine ....
For me I got 4x2-way switches and 2x3-way....... Pots not visible from channel monitor ....
23 Jan 2018 16:21 - 23 Jan 2018 16:30 #67077
Are you sure? On the mainboard image I definitely see connections and diodes for four 3-pos switches and connections for two 2-pos switches. The original "hardware.ini" enabled four 3-pos switches and two pots (AUX4 and AUX5).
It looks like shoulder switches connected to AUX4 and AUX5 lines. So they havn't names. I don't know for what they used.
Last edit: 23 Jan 2018 16:30 by vlad_vy.
- SeByDocKy
23 Jan 2018 17:19 #67081
by SeByDocKy
;enable-haptic=1
;voice=
;voice-uart5=1
;extra-buttons=
[modules]
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
has_pa-nrf24l01 = 1
- SeByDocKy
23 Jan 2018 17:22 - 23 Jan 2018 17:22 #67082
by SeByDocKy
For my radio only the switches A & B are 3-way ..... other are two-way
First bug I found ... with the current deviationTX installed (T8SG based from 09-19)... As soon as you open the USB device... then after radio refuses to be turned on .... You need to disconnect the battery plug
Last edit: 23 Jan 2018 17:22 by SeByDocKy.
- antennenfreund
23 Jan 2018 22:35 #67091
by antennenfreund
My remote control came today too.
But I do not know how I can tie .. it does not work.
The recipient of this is ... I do not know what I have to hire.
www.banggood.com/818CH-Mini-Receiver-Wit...earch&cur_warehouse= CN
How does it work? The receiver flashes .. then I go to bind .. but nothing happens.
Then I bought another receiver.
This one:
hobbyking.com/de_de/frsky-r-xsr-ultra-mi...iver-eu-version.html
It is EU version!
I have FrskyX set .. synonymous EU!
I hold the button and put the battery to it. All lamps light up permanently.
I go on bandage and nothing happens! What am I doing wrong?
This one:
It is EU version!
Time to create page: 1.078 seconds
- iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
