08 Feb 2018 04:12 #67441 by ajtank
Replied by ajtank on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
antennenfreund wrote:
plmask wrote: Adjusting the fine frequency by 63 worked for binding the Frsky D8 receiver. Thank you.
Range check with 100uw worked at 30 feet.
30 feet?????
that is very very little. There you will have no problems.
3000 feet must go!
with Frsky and this station is only 200 to 400 feet!
That is far too little :(
His range test was done at 100uW, not full power.
09 Feb 2018 08:17 - 09 Feb 2018 08:18 #67450 by vlad_vy
Replied by vlad_vy on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
Confirmed. The "B1" connector intended for vibration motor. The upper contact (-).
Last edit: 09 Feb 2018 08:18 by vlad_vy.
12 Feb 2018 09:40 - 12 Feb 2018 09:41 #67470 by nille
Replied by nille on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
In Germany there are only 100 allowed by law.
There is no difference between 100 and 15mW. Same result: lost signal after 2-3m DSMX / DSM2
Last edit: 12 Feb 2018 09:41 by nille.
12 Feb 2018 09:56 - 12 Feb 2018 10:03 #67471 by MikefromGermany
Replied by MikefromGermany on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
None of your club guys owns a simple RF spectrum analyzer?
Easiest way to check your gear.
Thirdmost important thing a serious hobby fellow should buy after a decent TX (NOT counting the iRange as that!) and a good charger imho.
edit: even no access to a RF power meter?
2nd edit:
I could check it for you, but then you won't get a chance for a replacement.
Last edit: 12 Feb 2018 10:03 by MikefromGermany.
12 Feb 2018 10:03 - 12 Feb 2018 10:10 #67472 by vlad_vy
The reason can be outside RF module. If you have good range with only one RF chip (probably A7105), then your problem most likely located outside RF module. The way from RF chip to PA/LNA chip switched by external signals (PE1 and PE2, pin 3 and 4 of RF module). I think PE1 and PE2 encoder chip located on back side of mainboard.
Last edit: 12 Feb 2018 10:10 by vlad_vy.
12 Feb 2018 17:55 #67474 by antennenfreund
Replied by antennenfreund on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
OliverST wrote: Does anyone fly a tiny6 with the small frsky Receiver which can be chosen when ordering the tiny6?
I have a lot of problems with the range, maximum isabout 30 meters and then the tiny falls from the sky. 150mW and tried freq-fine from 10 to 70 but this helps only a little bit.
Has anyone an idea how to fix this range Problem???
i would also like to fly a bigger drone (diatone gt200s) but not with this range porblems :-(
Hello
I also had the same problems as you!
Unfortunately you have received a defective RX module.
Swap the remote control. I got a new one from Bangood.
The works without problems!
12 Feb 2018 18:18 #67475 by antennenfreund
nille wrote: In Germany there are only 100 allowed by law.
Also you have a broken RX module!
12 Feb 2018 18:20 #67476 by FDR
You mean TX module, don't you?
13 Feb 2018 04:35 #67484 by antennenfreund
FDR wrote: You mean TX module, don't you?
I mean the remote!
Sorry,...
15 Feb 2018 20:23 #67521 by Ariete
Replied by Ariete on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
I just received one of the white iRangeX iRX-IR8m.
Switches B and A are three 3- position and C , D and side switches are toggle.
Not Ideal because I am used to Devo 8S and usually my models have the flight mode on the side switch which is three positions.
Maybe I can exchange places of switches and change some of the toggle switches to 3-position switches. The idea is that when I copy my models from the Devo 8S all the switches will be in the same place.
I encountered the same problem that other people have mentioned here. When I power off I have to wait some time before it can be powered on.
Do you recommend to change the firmware?
16 Feb 2018 03:53 - 16 Feb 2018 03:54 #67527 by vlad_vy
You can replace switches "C" and "D" to 3-pos switches without any mod.
You can fix power Off/On problem by changing capacitor:
www.deviationtx.com/forum/6-general-disc...tocol?start=80#67296
You can get normal shoulder switches "G" and "H" (initially they connected to AUX knobs and havn't names) by simple mod:
www.deviationtx.com/forum/6-general-disc...tocol?start=60#67227
Yes, will be better to flash latest firmware.
Last edit: 16 Feb 2018 03:54 by vlad_vy.
16 Feb 2018 18:51 #67541 by Ariete
vlad_vy wrote: You can replace switches "C" and "D" to 3-pos switches without any mod.
Thanks vlad_vy.
Not sure about soldering, at the moment, though.:)
16 Feb 2018 22:44 - 16 Feb 2018 23:30 #67546 by Hayataro
Replied by Hayataro on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
Hi vlad_vy-san, :)
I tried a mod about switch G,H but not worked. Maybe I had some mistakes.
Please inform me more in detail?
T8SG and iR8M is quite differ , so I could not understand wireings.
It's will great help if you can show simple diagram/schematic of this mod.
I'll take pics and upload how to mod description to RCG and here.
using same ID in RCGroups.
Last edit: 16 Feb 2018 23:30 by Hayataro.
17 Feb 2018 00:34 #67548 by plmask
Replied by plmask on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
My transmitter has a problem with the throttle gimbal, it will not return to zero. Banggood has acknowledged the problem and has stopped shipping the units. They said the next batch will fix the issue. I requested a new transmitter since there are clearly quality problems with the first batch shipped. They said no and instead shipped me a replacement gimbal. Not happy with that response since there are clearly other quality issues beside the gimbal. They have also stopped allowing customers to post anything on their site for this item. Very disappointed especially since I have bought hundreds of items over the past 5 years from them. I would advise anyone thinking about purchasing this transmitter to look for something else instead or wait for this issues to be completely resolved before buying it.
19 Feb 2018 09:06 #67580 by antennenfreund
We have now tested 3 of these remotes. Unfortunately, all with the same result.
The RX module is very very bad. FrskyX is not working properly.
The range is very low. (100 feet)
We can only buy this remote maintenance. They do not bring good results. Unfortunately ... we are very sad about it.
Always problems with the range at Frsky.
19 Feb 2018 10:33 #67581 by Alvarez
Replied by Alvarez on topic Futaba protocol
Hello everyone sorry about my English level firtly
1-I have bought this transmitter and I try yo connect my plane with futaba s-fhss protocol but i can't do it i follow allí the rules about It Big the transmitter use "re-unit " and I don't know what happen
2- i don't able yo use the 3 ways switch there are a strange mix how do you solve this problema
My firmware versión is 2018-2-14
19 Feb 2018 12:15 #67584 by wdlee
Replied by wdlee on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
Thanks vlad_vy.
19 Feb 2018 15:39 - 19 Feb 2018 15:45 #67590 by vlad_vy
Hayataro wrote: Hi vlad_vy-san, :)
See the image from above post. But for me, I would connect diodes to other outer switch pin.
Last edit: 19 Feb 2018 15:45 by vlad_vy.
20 Feb 2018 16:39 #67632 by plmask
Stefan_UK wrote: Hi and thank you, I watched the video which is most informative I have quality issues much the same as others. Both gimbals do not centre properly even after numerous attempts at calibration +8 and -17. The right-hand gimbal on my TX when in the home position doesn't even align with the centre markings. My less than favourable review was never published by Banggood my less than favourable comments no bad language just saying much the same as here never published. I am not allowed to post another review for this product because apparently, only people that purchased this product can submit a review. Well, I have my order details proving I purchased this product from Banggood. Only good reviews are currently being allowed on Banggood for this product. Anyway, I've been in correspondence with Banggood and have asked them to send me a replacement Gimbal Kit. I know the state of my purchased product if I can get replacement gimbals good ones from Banggood better still compatible gimbals of higher quality this would become a nice usable TX. I just love the DeviationTX platform its so easy when I'm in a rush to fly compared to open source TX on my Taranis. Regards, Stefan
PS I only really bought this TX to fly my Tiny models around the house during our Winter time here in the UK.
Banggood did the same to me Stefan. Not allowed to post even though I purchased the product. I requested a new transmitter but they appeared to mis-understand my request and sent a replacement gimbal instead. I have purchased a couple thousand dollars worth of merchandise from Banggood over the last 6 years, I'm very disappointed in their customer support on this issue. iRangeX let Banggood down and they in turn let us down. Going forward, I will only consider buying low cost items from them.
24 Feb 2018 14:11 #67739 by IKKI
Replied by IKKI on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
Bad range for me...
But great idea and try to fix
Time to create page: 0.880 seconds
