24 Feb 2018 14:15 #67740 by Alvarez
Replied by Alvarez on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
How do you do that?
24 Feb 2018 14:20 #67741 by IKKI
Replied by IKKI on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
I have not done anything yet. I arrived today and I did the first range tests. Very poor compared to my 10 o'clock. But aesthetically I like the idea of ​​a fpv screen positioned above.
24 Feb 2018 17:02 #67742 by WimH
Replied by WimH on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
Just got mine today.Knobs for the top pots missing.... Flashed the latest software without problems and after that the return to neutral does not seem too bad with mine . Hope range is OK too... But one problem, when I turn it on after installing latest software it says CYRF6936 chip is missing??? All protocols using this one are marked with a * ???
24 Feb 2018 17:36 #67744 by vlad_vy
Replied by vlad_vy on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
I don't understand how it possible. Can you provide original "hardware.ini" file?
25 Feb 2018 11:48 - 25 Feb 2018 11:49 #67761 by WimH
vlad_vy wrote: I don't understand how it possible. Can you provide original "hardware.ini" file?
If you mean before update, no. This is the one I have now
File Attachment:
File Name: hardware.ini
File Size:1 KB
Last edit: 25 Feb 2018 11:49 by WimH.
25 Feb 2018 11:58 #67762 by vlad_vy
It's standard "hardware.ini". It doesn't help to understand why after installing latest software it says CYRF6936 chip is missing.
25 Feb 2018 12:05 #67763 by WimH
it gets weirder... After I started the TX in USB mode to copy the file and also opened it to check the contents, the error is gone, startup is normal now???
25 Feb 2018 13:12 - 25 Feb 2018 13:12 #67764 by vlad_vy
Probably something is wrong with filesystem. Try to format USB drive, write filesystem and use "Safely Remove Hardware".
Last edit: 25 Feb 2018 13:12 by vlad_vy.
02 Mar 2018 21:25 #67860 by IKKI
Guys, but have you done range tests? With the NRF24L01 module I have 1/3 compared to my I have 10 and with the protocols Dsm is something ridiculous ... Worse than I have 7. Without long range mod. Do yours go better?
03 Mar 2018 13:53 #67881 by nille
Replied by nille on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
I sent my TX back to banggood. Banggood will reimburse me for the cost of the shipment and the purchase price.
07 Mar 2018 12:11 #67955 by plmask
Replied by plmask on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
The iRangeX iRX-IR8M failure is now complete. The hardware design, manufacture, distribution and service was not up to the lowest basic requirements and expectations of an RC community that has been around for more than 50 years. Banggood's failure to openly acknowledge the concerns of it's customers and actively suppressing negative comments on their website sends a clear message, you can't trust them to do the right thing for customers.
09 Mar 2018 18:32 #67982 by GabrielRB
Replied by GabrielRB on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
I tested with two frsky receivers D8RII and D8RXP. At 100uW I achieve 50m without problems, It can reach 60m I believe....
At 150mW it is 1500x bigger than 100uW so theoretically distance will increase by 38x given to us ~1,9km. But again, theoretically.
10 Mar 2018 10:23 #67994 by wdlee
Replied by wdlee on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
Hi.
I connected the trainer port and tried to connect the vibration motor.
Fortunately, it was successful.
This unit has a universal vibration motor hole. But I had to make a separate case to connect the remaining motor.
I can not understand why these things were not installed from the beginning
I can not trust this device.
13 Mar 2018 09:01 #68038 by Tonny
Replied by Tonny on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
My iRX-IR8M suddenly displayed the USB logo and it stopped working. Whichever button I press does not respond. Upload VIDEO. Can anyone tell me how to recover?
13 Mar 2018 10:49 #68039 by vlad_vy
Format transmitter USB drive and copy filesystem from firmware archive:
www.deviationtx.com/forum/builds/7605-ir...uilds?start=20#67668
13 Mar 2018 13:41 #68040 by Tonny
My iRX - IR 8M was revived. Thank you very much.
15 Mar 2018 14:49 #68091 by Alvarez
You need yo use ibus and the ibus pin on your fc
15 Mar 2018 15:19 #68092 by vlad_vy
16 Mar 2018 13:28 #68128 by škrat14
Replied by škrat14 on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
Hi my travsmiter irange x locked in usb mode tried everything but nothing happened
please help
16 Mar 2018 14:40 #68133 by vlad_vy
I need voice mail for this question.
www.deviationtx.com/forum/builds/7605-irangex-irx-ir8m-builds
Time to create page: 1.194 seconds
